View Full Version : Where does this hose go on my LS1??
skeeters65
11-16-2008, 09:14 AM
The motor is a 2002 F-body LS1.
Looking at the motor from the front of the car there is a small diameter hose coming out of the (I Think) water pump below and to the passenger side of the throttle body.
Just wondering what it is supposed to be hooked up to??
THanks
dhutton
11-16-2008, 10:23 AM
Sounds like the steam vent line. It is supposed to return to the radiator at the highest point possible. There are some other ways to do it, try searching on ls1tech.com.
Don
Tyson A
11-16-2008, 12:46 PM
Not sure on that exact ls1 but the last one I owned had a hose that went to the throttle body. Something about freezing temp areas of the country and you could do a bypass if low temps would not cause you any problems
Tyson A
11-16-2008, 01:04 PM
Here is the mod i'm talking about hopefully that's the hose your talking about or I just wasted your time
http://www.ls1tech.com/forums/generation-iii-external-engine/924077-tb-bypass-mod-writeup-pics.html
skeeters65
11-16-2008, 05:07 PM
Thanks dude that is the hose I was talking about.
What is the point of doing that mod? What does it do and why is it better??
dhutton
11-16-2008, 05:58 PM
It is the steam vent to keep steam from getting trapped in the heads. The purpose of the mod is to no longer have the line pass through the throttle body. It is used to warm up the throttle body in cold weather.
Don
Tyson A
11-16-2008, 10:53 PM
Dyno runs before and after the mod show between a 2 and 3 hp gain with the mod. By doing the mod you reduce your air temp entering the motor.
Throttle
11-16-2008, 11:19 PM
Yeah, I did this to the motor in my truck..
