Buffalobillpatrick
11-14-2008, 12:44 PM
Hello, new guy here (really old retired guy) 1st post.
This is kind-of a build along & question along thread. I have never done this (successfully) before.
I'm setting up 1972 Chevy passenger 12 bolt rear-end, (8.875" ring & pinion).
I picked up "pumpkin" at a bone yard & cleaned it out completely, looks good.
all other parts are new.
I have a Richmond 456 ring & pinion, Moroso Posi, Strange axles that are C-clip eliminator type, Timken bearings.
I welded the tubes into the center section & cut off the tubes just past the 4 bolt flanges, this is required for the Strange axles. Tapped the 1/8" NPT vent hole & Re-cleaned everything.
I'm trying to setup the pinion depth to 2.791" Richmond calls it the "checking distance" (this is the distance between the flat circle of pinion head to the centerline of the carrier bearings)
Also setting the pinion new bearing pre-load (25-30 inch-pounds)
The large pinion bearing inner race was a very tight fit to the pinion shaft, so (not being the sharpest knife in the drawer) I greased the race & shaft, put in a .025" shim between the pinion head & the inner bearing race & pounded it on with a brass drift, avoiding any contact with the bearings. (I have no press) Then heated up pinion shaft with a torch & re-pounded the race to make sure it was on all the way, (it's in & it's stuck).
Later when dealing with the small pinion bearing inner race, I found that I could easily reduce the pinion shaft by putting pinion in my bench vice & "shoe-shine" it with a 1" wide x 18" long strip of emory cloth stuff that I use for cleaning copper pipes, 1 minute tops. (I wish I had thought of this before I beat the large bearing on)
I got a Ratech pinion depth setting tool,
http://store.summitracing.com/partd...15&autoview=sku
Has anyone else used this? I hope it will be accurate.
Now I'm waiting on a depth micrometer from Amazon to put through the hole in the above tool to measure down to where the carrier bearing outer race will sit.
I also bought a Ratech solid spacer kit 1901,
This takes the place of the normal crush sleeve & 6' breaker bar method (GM's revenge, oops I went too far method, he he).
This solid spacer & shims are used to set the distance between the pinion large & small bearings, which sets the pinion bearing pre-load (new 25-30 inch-pounds)
This kit provided shims that go between the "pumpkin" housing and the large pinion bearing race. I can easily, (with a brass drift), beat the large pinion race out of the housing from the front end as there are reliefs machined in the housing for this purpose.
Has anyone else used this kit or put shims between the housing & the large bearing race?
To be continued:
BBP
To be continued:
BBP
