JMarsa
11-12-2008, 10:42 AM
After too long I'm officially starting my build. Don't worry, pics will get posted this weekend. I've been collecting parts and tools over the last few years and I'm finally ready to get "started". Don't expect much bling, high dollar parts, or daily updates. There will be a lot of chassis fab and prerequisites for the various stages so progress will be slow. I work 50+ hours a week and have a family so the weekends are about all I have and they are often are tied up with other commitments. I'll break the build threads into sections to keep it organized.
So let's get started shall we?
Task 1 - Media Blast under carriage and wheel wells.
I checked out the local shops which are all about the same price (thanks for the leads "GRIMMEY71" and "GBodyGMachine") and have the choice of the following media types (descriptions pulled from the net, not my a$$):
1. Urea is a plastic grain stripping abrasive used in sandblasting operations. It is the most widely used plastic media. Urea is environmentally friendly and recyclable - an alternative to chemical stripping. Urea is formulated to meet an increased level of stripping performance where stripping speed outweighs other considerations. Urea is able to strip tough coatings with an impressive strip rate. Urea is typically used for less sensitive applications. Standard mesh sizes 8-12, 10-20, 12-16, 16-20, 20-30, 30-40 and 40-60. Sizes 12-20, 20-40 and 60-80 can be specially ordered. Packaged in 50 lb boxes or bags or 250 lb drums.
2. Starblast™/Sand is a general-purpose staurolite abrasive used in steel fabrication and bridge maintenance to remove rust, mill scale, and weathered coatings
3. Steel grit blasting is ideal for aggressive cleaning applications. Steel grit will quickly strip many types of surface contaminants from steel and other foundry metals. Steel grit is softer than aluminum oxide and does not fracture as easily, making it ideal for aircraft and aero-space applications. The angular nature of steel grit produces an etched surface on metal for superior adhesion of paint, epoxy, enamel, rubber and other coatings.
Using the poll:
The question is, for a car with solid floors that was Ziebart'd when it left the dealer and spent 10 years on dirt roads (I've never powerwashed the undercarriage), which one is best?
--JMarsa
Using the poll:
--JMarsa
