View Full Version : Dry Cutting Metal Bandaws - Blade Life
JMarsa
11-10-2008, 05:17 PM
I'm thinking of getting a horizontal band saw. I expect that blades wear our quickly for the dry variety and that over the years, I'll go through enough blades to warrant the upgrade to one that uses coolant.
Any comments?
--JMarsa
hotrdblder
11-10-2008, 05:37 PM
some of the better band saw do not recommend coolant, i have a horizontal, ellis and they hate coolant and no you won't go thru alot of blades as long as you buy the proper blade for the proper material, blade life highly hangs on you have the appropriate amount of teeth in the work peice.
what brand are you looking at? ellis are made int he u.s and high quality but come with a price tag
JMarsa
11-10-2008, 06:31 PM
I've only used wet saws in real metal shops, this is for hobby use. I like the idea of the horizontal/vertical combo but I might be able to get away with a jigsaw, reciprocating, or plasma instead with a horizonal only. I hate having the wrong tool for the job.
I'm debating between these:
this wet (http://www.grizzlyindustrial.com/products/6-1-2-x-9-1-2-Metal-Cutting-Bandsaw/G4030)
and
this dry (http://www.wttool.com/product-exec/product_id/41297/nm/4_1_2_Metal_Cutting_Bandsaw_with_Angle_Cutting_WT_ Import_)
Both are imports. I'm leaning towards the latter.
--JMarsa
astroracer
11-11-2008, 08:58 AM
For hobby use that saw will do fine. I have a 25 year old Tiawanese 4x6 horizontal that I use all the time with no blade issues. In fact, the current blade has been on there for a couple of years now. I cut everything with it, wood, aluminum and steel.
I use bi-metal blades exclusively and these are purchased through Enco (usually on sale).
Mark
Otto-813
11-14-2008, 02:14 PM
I have a Dake SE-712 and used the blade for over a year before finally changing it. It is a wet saw and I did a lot of cutting with it.
But it is a little pricey when compared to the knock-off ones.
http://www.southern-tool.com/store/media/dake/bandsaw-johnson-se712.jpg
JMarsa
11-14-2008, 05:00 PM
Nice. It's vertical as well. I wish you lived nearby!
--JMarsa
hotrdblder
11-14-2008, 05:05 PM
http://www.ellissaw.com/Band-Saws/12/1500-mitre-band-saw
these are about 2500 new made in usa
theres mine, check ebay and buy a good used high quality one before buying a new import one, quality is incomparable, price is also but thats why i say buy used quality one
Jim Nilsen
11-15-2008, 04:43 PM
Check out Jet and Delta for brand names and last but not least check out good ole SEARS Craftsman. Remember that the Craftsman will help out the paycheck of a serving soldier.
You can find all of these on line and see what the prices are and the capacities.
Goodluck.
BMF Machine
11-15-2008, 04:58 PM
I use a jet. I have HAAS CnC's, but a saw, is a saw. Take care of them, never crash the blade down to hard, it will be fine. Mine is big and cost around 3500.00 I am sure the smaller ones are nice as well. I cut mainly A-2(Hard stuff), it never fails me, I love it. I was unsure at first. But I take care of it, nothing is worse than an old worn out saw.IMO.
