View Full Version : c6 z06 brakes and air ride spindle??
muthstryker
11-07-2008, 04:05 PM
Does anyone know if the spindles provided with the air ride street challenge kit would allow for c6 z06 brakes? I tried emailing airride awhile ago and havent heard back thought id check here.
The WidowMaker
11-07-2008, 06:45 PM
the short answer is that you need to call tobin at kore3.com
the slightly longer answer; if the spindle accepts the stock brakes, that means that it should be similar in mounting pts to the stock spindle. tobin has a kit for the stock spindle, so it should work.
does the air ride stuff have a hub, or is like the stock stuff?
tim
Apogee
11-07-2008, 06:58 PM
I haven't had my hands on any of the "Ridetech" spindles that weren't under a car, but several of our customers have run them with our GMSS kits with our hardware kit for the OE disc spindle applications without any issues. Just to be safe, I'd suggest letting AirRide confirm or deny it...but you'll probably need to wait until after SEMA to get an answer.
Tobin
KORE3
LSXfan
11-07-2008, 09:07 PM
they're OE disc brake type spindles with a 2" drop built in and 2" taller ball joint mount
muthstryker
11-09-2008, 12:58 AM
Will the ATS AFX spindles work on the strong arms??
130fe
11-09-2008, 06:17 AM
I talked to Tyler at ATS and he said they would work. That is what I am planning on doing.
muthstryker
11-09-2008, 07:14 PM
then it looks like thats what im going to do. thanks everyone.
