View Full Version : 1969 camaro rear wheel fitment
bobhamilton15090
10-27-2008, 06:32 PM
Can I run a 20x10 wheel with 4.5 bs on a 1969 camaro?
dhutton
10-28-2008, 04:16 AM
Not likely. Most commonly recommended backspacing for a 10 inch wheel is between 5.5 and 6 inches, not too mention the 20 inch wheel which is going to make it even tougher.
Don
bobhamilton15090
10-28-2008, 08:44 AM
could i use a 1" spacer?
JayR
10-28-2008, 09:20 AM
The spacer is definitely not the way to go as it will push the wheel an inch further in the wrong direction. You need the opposite of a spacer, i.e. a narrowed rearend and minitubs because your wheels need to go inboard to clear everything, not get pushed outboard.
bobhamilton15090
10-28-2008, 05:05 PM
thanks for the info. these wheels are not worth the headache even if they are cheap!
JayR
10-28-2008, 10:45 PM
Let us know if you need a set built exactly for the car. www.RushforthWheels.com (http://www.RushforthWheels.com) We've fit a ton of 1st gens and can have them ready for you in 4 weeks.
Here's Kenny Davis rocking a set of our 19 & 20" Rated-Xes. As you can see, they don't rub!
https://static1.pt-content.com/images/pt/2008/10/KennyD-1.jpg
bobhamilton15090
10-29-2008, 09:05 AM
I would love some of your wheels, they look incredible. My issue is cost, I am running over budget on the car a we speak and I have a wife to answer to!
JayR
10-29-2008, 02:47 PM
I hear you, Bob! Divorces are a lot more expensive than wheels. Keep her happy and find the right wheel within your budget.
Good luck!
