View Full Version : How many CFM for filter??
skeeters65
10-15-2008, 04:06 PM
2002 LS1 with Texas speed Magis Stick 3 cam.
How much CFM does my air filter need to flow??
Shawn MacAnanny
10-16-2008, 11:36 AM
2002 LS1 has 241s on it which flow something like 230 cfm i believe. So 230x2 is 460 so say roughly 500cfm right? I'm just guesing really.
skeeters65
10-21-2008, 09:31 AM
anyone else??
LSXfan
10-22-2008, 06:18 AM
Cfm= Cid X Rpm X Ve / 3456
camcojb
10-22-2008, 07:22 AM
the stock throttle bodies usually are in the 750-800 cfm range with normal pressure drops and flow procedures; higher if you accept larger pressure drops. In other words, you can almost make them flow whatever depending on how you test them, but the above cfm should be close.
I would want a filter that was larger flow just so it's not a restriction, larger the better as long as it fits where you're mounting it.
Jody
