View Full Version : 66 mustang sizes
spaghettio
10-10-2008, 05:25 PM
can somone help me out on what i can fit on the rear of my 66 mustang?
NOT A TA
10-10-2008, 05:30 PM
Welcome to the forum! I'm not much help though on your question. The biggest I've ever tried on my 66 with stock wheelwells was a 245 on a 7" rim. No problems with that.
spaghettio
10-10-2008, 05:43 PM
thank you for the fast reply what size wheel is that an 18 maybe?
NOT A TA
10-10-2008, 05:54 PM
If I remember correctly they were 245 60 15's. I'm moving the rails in, narrowing the tank and mini tubbing mine. Go to the wheel & tire section check the database thread and do some searches. I'm sure you'll find a bunch of people with 17's 18's.
spaghettio
10-10-2008, 06:57 PM
thank you for your help
65STANG
10-12-2008, 02:00 AM
I have a 65 Mustang coupe project and have trial fitted a set of 255/17/40's. They fit fine although I am cutting my diff to suit the wheels. I probably could have fit 265's but they would be pretty tight and may have rubbed when the tires flex through corners.
spaghettio
10-12-2008, 06:55 AM
yea im having trouble with the tire hitting my leaf sping before it even touches in the front. does anyone no of somone making offset shackles for a 66 stang?
Z06killinSBF
10-12-2008, 08:51 AM
Go to stangnet.com and in the classic tech forum is a wheel guide about what fits. I know a guy running 275/17's with no mods. I fit a set of 255/50 16 DR's on mine with only minor rubbing on the fender.
spaghettio
10-16-2008, 03:13 PM
i would like to run a 275 18 what would i have to do to get them to fit. i cant seem to find offset shackles for my leaf springs. i thought about maybe building a custom set? the tire hits the leaf springs before it hits up front.
Z06killinSBF
10-17-2008, 11:48 AM
No one makes offset shackles for the Mustangs. You would need to reweld the front boxes in anyways once you move them. A short 275 should fit with only using a BFH.
Click on this for different set-ups. http://www.dodgestang.com/emAlbum/albums/Tire%20and%20Wheel%20Charts%201965-1973/Tire%20and%20Wheel%20Chart/Tire%20Fitment%20Guide%2065-6.pdf
275's
https://static1.pt-content.com/images/pt/2008/10/rco20034-1.jpg
pro-touringAK
10-19-2008, 04:24 PM
not sure of the difference between a 68 and 66, but I'm running stock locations on my rear leafs only a mid eye for lowering. I have 18x9 forgot the offset and am running 265/35/18. I could easily have run a 275 and a 9.5 width rim.
spaghettio
10-29-2008, 09:59 AM
:postpics:
any body have pictures of stangs?
pro-touringAK
11-01-2008, 01:27 PM
This is my 68 coupe. Lowered the front 1.5" and the rear 2". I definately think I would have room to run a 275/35 or even a 285 in the rear. The rims are 9" wide, could have gone with 9.5". Fronts are 8" wide. As for offset I will have to look around to get the numbers.
