View Full Version : Mini Tubs Wheelhouses on ebay
blainemeyer
10-05-2008, 03:20 PM
Anybody have any experience/info on these mini-tubs ??? Anybody have them installed ??
http://cgi.ebay.com/ebaymotors/1969-Camaro-Firebird-Mini-Tubs-Wheelhouses_W0QQcmdZViewItemQQ_trksidZp1638Q2em118 Q2el1247QQcategoryZ34204QQihZ016QQitemZ26028825707 2QQrdZ1QQsspagenameZWD1V
XLexusTech
10-05-2008, 03:36 PM
for the 50 bucks why risk it
zbugger
10-05-2008, 06:33 PM
That actually looks pretty interesting being that it's $350 for both the inner and outer already welded together. Although I'd be interested in seeing how difficult the install would be without removing the fender.
mikey
10-05-2008, 09:39 PM
I think it would be nearly if not impossible to do. I've heard of that seller but never bought from him. He's on here or camaros.net.
Fireeater
10-06-2008, 01:05 PM
I've bought from Matts before. Very nice to deal with.
MCC
10-06-2008, 01:51 PM
This complete minitub wheelhouse are made by ( GLA/DII )Golden leaf automotive They are just 2" wider than stock . MSRP is $ 135.00ea
MarkM66
10-06-2008, 02:21 PM
Are DSE tubs 2" wider?
MCC
10-06-2008, 03:44 PM
DSE tubs are 2.75" wide . MCC tubs are 4.65" wide .
blainemeyer
10-06-2008, 03:47 PM
I know the DSE product are great but its nice to have a choice and if you need new inners and outers anyway this may be a less exspesive options.
XLexusTech
10-06-2008, 04:37 PM
Not sure if this is double talk or not. Obviously the 4.65 inches includes the outer wheel house. Maybe a rephrase is in order.
Excluding the outer wheel houses how do the MCC inners ONLY compare is size to the DSE inners?
Motown 454
10-06-2008, 08:05 PM
I'm pretty sure they are almost 2" wider than DSE . Mike is only measuring the inside tub.
MCC
10-07-2008, 05:46 AM
MCC Tubs are 2 " wider then DSE Tubs. This is Y we made custom rear frame rails to work with them .
-Mike Riggs
www.mikescustomcars.com (http://www.mikescustomcars.com)
XLexusTech
10-07-2008, 06:06 AM
-Mike Riggs
Cool now were geeting to the meat of this. they are wider 4.75 inches wider the Original in the inner housing. DSE is 2 inches wider then OE on the innser tub. To go 4.75 I could se why they would require custom frame rails.
MCC
10-07-2008, 11:22 AM
Stock inner wheel tub = 4.25 " ( 0 " )
DSE inner wheel tub = 7.00 " ( 2.75 " )
MCC inner wheel tub = 9.00 " ( 4.75 " )
XLexusTech
10-08-2008, 05:51 AM
Just a thought If you can make these and sell them cheaper then the DSE with the outers included. Could you make available a set that does not require a new framerail for the same or less (with just a + 2.75 instead of a + 4.75) ??? If so sighn me up I need a set.
Rhino
10-08-2008, 02:54 PM
Do you have just the inners available for us 67-68 owners?
MCC
10-09-2008, 01:17 PM
The GLA minitubs (2") are just sold as a inner and outer welded part. You can't get just the inner from them.
You can just get the inner from DSE (2.75") and the inner from MCC (4.75 ").
MarkM66
10-09-2008, 01:38 PM
Maybe I'm wrong, but if a 335 on an 12x18" wheel barely fits in a 2.75" DSE tub, a 2" tub doesn't have enough room to justify the cost of getting a wheel wider then 10" .
minendrews68
10-11-2008, 05:43 PM
I too have bought from Matts, and yes, a pleasure to do business with. They also are good with customer service. Great bunch of people.
bobhamilton15090
10-25-2008, 04:03 PM
what is the widest tire you can run in these 2" wider wheel tubs?
GaRys69
11-15-2010, 03:34 PM
Yearone has 2" inners for 1st gens.
Think they are around $200.
Project69
11-15-2010, 04:09 PM
Strong bump dude
durrettcustoms
11-15-2010, 04:10 PM
DSE makes a great product!
chops101
11-15-2010, 09:28 PM
I bought these from Matt (great guy) and other things previously, and I am 3000 miles away from his place.
I have a 69 RS/SS Vert Camaro with quarters probably replaced 10 years ago ?? .....Before my time so don't know really when they were replaced. My inner and outer wheelhouses were patched on both sides, so it was an easy decision to try these minitubs, I needed inner and outer anyway. Yes I did it with the quarters on. I did take the inner and outer apart (very easy) to make a custom fit.
My specs:
I did not cut the frame rails
Leaf springs moved 1" inboard each side
Shocks moved inboard of springs
I made my own custom 1" offset shackles
Axle perches moved accordingly 1"
Stock fuel tank retained
Going with 18x10" rim, an 11" would certainly fit but cannot justify the extreme upcost
305/35/18 is as big as I want to go (12.4" wide), the 305 mock up is a great fit.
