View Full Version : port
hifi875
09-28-2008, 08:26 AM
newbie to the lsx technology. I have acquired a car with a lsx/t56 combo. the driver side head has a port at the very back that i can see a little vapor or smoke coming out of when engine is running. what is it, and what should i put on it.
SatisTraction
09-28-2008, 09:51 AM
post up a pic. sounds like the temp probe location.
Shawn MacAnanny
09-28-2008, 10:33 AM
It might be the steam vent line runinng under your intake. This attaches to both heads then your throttle body then to your radiator. Is this where you are seeing it come from?
hifi875
09-28-2008, 04:20 PM
i'm not home, but the port? stands up 90 degrees and looks like it should have a hose connected to it.
Shawn MacAnanny
09-28-2008, 04:27 PM
Oh on the valve cover? Like where my duct tape is in the pic? That's your PCV (Positive crankcase ventialtion) hook up. The PCV valve goes in there and that goes to your throttle body ( i think if i rember right)
hifi875
09-28-2008, 05:09 PM
I think your'e right. where does it go on the throttle body? excuse me for my stupidity. thanks
Shawn MacAnanny
09-28-2008, 05:16 PM
To be honest im not even sure it does go to the throttle body. I THINK it does on these engines. See i converted mine to carbureted so i am not sure. I ran mine to the back of my carb haha. There should be a check valve in the fitting, it might me a 90 degrees fitting or 180 degree fitting.
