    Results 1 to 20 of 25
      May 2008
      SoCaL-Pico Rivera
      Chevelle with c5 zo6 brakes
      I would like to know if I need to run a hydroboost when I run these brakes or will the system I currently have work. I have disk/drum set up factory and a booster.
      Marshall , MO
      They should work with the booster you may have to change your master cylinder.
      Brad Shepard
      69 Malibu
      Marshall, MO
      Oregon
      The factory MC for a power disc/drum setup was 1-1/8" bore. You'll want to swap that out for something closer to 1" since your overall caliper piston area has been reduced relative to the stock calipers. If your engine doesn't generate adequate vacuum at idle (12-14" Hg or better) to effectively power the brake booster, hydroboost would be a much better option...or manual. All can be made to work and work well, but making a vacuum booster work with an engine that doesn't produce any tends to be a costly endeavor for what you get.
      Tobin
      KORE3
      It's what I does.
      Feb 2007
      Southwest Arkansas
      brakes
      I have a Kore3 brake kit on my 67 with a small booster and 1 1/8 bore master cylinder and it takes a large amount of petal effort to stop. I am going to change it to a 1" when I get some extra money.
      I just thought you might want to hear from some one who had made this mistake
      Clayton, C. David
      67 Chevelle/Malibu
      Poser-Touring
      Dec 2007
      I used a 70 Vette m/c on my 69 Camaro C5 front, C4 rear. Works great. Stock, I think, 11" booster
      Oregon
      Quote Originally Posted by B.W.T.ROAD
      When using the early 67-76 Corvette MC's with a vacuum boosted system, be sure to specify the manual 4-wheel disc application so that you get the 1" bore with the deep pushrod hole as the Corvettes with power brakes came with a 1-1/8" bore...same casting, just machined for the larger piston.
      Tobin
      KORE3
      It's what I does.
      Central Illinois
      Quote Originally Posted by Apogee
      Tobin
      KORE3
      Is that the oval one? Is there a similar application that uses the rectangular design?
      I'm running a '79 Trans Am master cylinder on my '68 442 that has ford explorer disks on the back and C5 brakes up front on ATS spindles. I think the bore is 1-1/8". The pedal is very stiff. I'd like to go down to a 1" bore.
      '68 442 convertible
      5 SPEED - EFI
      '66 442 Hardtop
      in process
      Dec 2007
      Williamstown NJ
      What seems to be the master cylinder of choice for the c5 brake swap..I am looking to purchase a booster/master cylinder combo for my setup as well. If the 11" stock booster is sufficient, what master cylinder do you use. WHat year and from what vehcles or is there an aftermarket one or late model one that bolts up. Also on another not, whats everyone doing for a proportional valve?
      1969 Camaro Pro Touring Project
      1991 GMC SYclone
      1985 Buick Gn w/ 87 engine
      1970 Chevelle SS Clone
      1967 Nova Future Pro Touring Car
      1987 Formula Firebird
      <!-- / sig -->
      I can tell you the 1" isn't quite enough line pressure. I'm looking to go with a smaller bore.
      I use an adjustable valve pictured in this post:
      http://www.chevelles.com/forums/show...17#post1679617
      Jun 2005
      Manassas, VA
      I too use a 1 1/8 MC, ATS spindles, C5 brakes front & rear, and have a pedal effort issue. I'm using an aftermarket 9" dual diaphram booster though, and to me it feels like there's not enough boost. I too was going to drop to a 1" MC, though I believe that might be a crutch. I've heard that going to a 7/8" MC isn't an option either, since ti will require more pedal effort. I believe 1" is about the max. From what I've been hearing, the real way to correct this is to go with a hydroboost.
      HWYSTR455 on PY
      1971 Lemans Sport 461 bottle fed daily driver
      1971 Trans Am 474 blown EFI pro tour car
      1972 442 W-30 clone
      Sep 2001
      Accord, NY
      I love hydroboost but make sure you have good sticky tires as you will easily lock up the fronts!
      69 Camaro convertible, 410, M22, 8-pt cage therapy program. SOLD.
      68 camaro - SOLD
      67 Bel Air - New street project with perfect floors, frame and trunk!
      Jul 2007
      Olathe, KS
      Has anyone looked into using the C5 master? It'd be my obvious choice when using C5 front and rear calipers. I'm sure there must be a reason it's not used.
      Aug 2005
      Hamilton, NJ
      C5 or 4th gen Camaro MC cannot be used?
      What Rick says about tire quality is true - I can lock my 15" hoops up just with 12" rotors & portfield pads (and otherwise stock brakes). So I can only imagine what much better braking would do!
      Scott from NJ.
      Vent Windows Forever! ...
      Jul 2007
      Olathe, KS
      Quote Originally Posted by BonzoHansen
      I guess that's my question. I've seen a few guys allude to it's use, although I haven't seen much about it actually being successful.
      https://www.pro-touring.com/forum/sh...ad.php?t=48572
      On another forum it was noted that the MC backing plate needed to be shaved down 1/4? Of course, it isn't stated what booster he's using.
      http://www.nastyz28.com/forum/showpo...95&postcount=3
      Aug 2005
      Hamilton, NJ
      What about this:
      The search was on to find a suitable master cylinder that could help generate enough fluid pressure (since the PBR caliper piston area is very small when compared to the iron Moraine stock calipers). A 15/16" bore master cylinder was found to come stock on S-10 trucks. It also featured the outlet ports on the same side as our stock Chevelle master cylinder & features SAE flared seats for the brake line fittings (unlike those found on other quick take-up master cylinders), but some machine work is necessary to fit into our early design Moraine booster.
      http://www.geocities.com/diels12000/BrakesII.html
      Scott from NJ.
      Jul 2007
      Olathe, KS
      I had completely forgotten about that. I'm not sure if there's a difference, but people on camaros.net have specifically spoken about using the 4x4 S-10 master with great success on a late model booster as well as hydroboost.
      Newer malibus had a 15/16" bore as well - no special machine work, ports are sae and on the proper side. I think the 1977 malibu should work -
      http://www.napaonline.com/MasterPage...Cylinder+-+New
      Central Illinois
      Quote Originally Posted by MJRIBEIRO
      Will that work for 4 wheel disks? I don't remember these cars having 4 wheel disk brakes from the factory.
      '68 442 convertible
      5 SPEED - EFI
      '66 442 Hardtop
      in process
      It should - you'll just need external proportioning to get the rear right. I'll give it a whirl this winter.
      Jul 2007
      Olathe, KS
      Do you happen to know where the residual pressure valves are for the Malibu? If it's built into the master, I don't think it would work. If it's in a distribution block then you may be ok.
      Drums need ~10 PSI residual pressure to function properly. This much residual pressure on a disk would surely cause brake drag. (I believe they require ~2 PSI.)
