View Full Version : Pics of 3" exhaust anybody have some??
Steve68
09-23-2008, 03:31 AM
Looking for some of the tail pipes, where they go over the axle, I've searched and haven't found much,
gordonquixote
09-23-2008, 05:10 AM
I had my mufflers installed under the rear seat pans and went under the axle and out to the rear tires. Full 3" exhaust with x-pipe.
I can jack the car up and the axle does not touch the pipes.
Procharmo
09-23-2008, 02:37 PM
I have installed Jegs 3" x-pipe, 3" Flowmaster Super 44's and Jegs tailpipes over the axle. Finished it off with Pypes tips. All solid and secure under 14 inch jackstands.
https://static1.pt-content.com/images/noimg.gif (http://imageshack.us)
https://static1.pt-content.com/images/noimg.gif (http://g.imageshack.us/img49/265sw5.jpg/1/)
[URL=http://g.imageshack.us/img87/266iw3.jpg/1/][IMG]
Steve68
09-25-2008, 07:17 PM
come on thats it???
skatinjay27
09-26-2008, 10:05 PM
wow theres one way to deal with a big bumper camaro! looks pretty good.
imo under the axle is less than pleasurably view from behind...
on any car.
gmjj13
09-27-2008, 07:24 AM
here's a couple of pics. i'm running the 3" magnaflow system with x-pipe in the stock location over the rear axles...hope this helps.
https://static1.pt-content.com/images/pt/2008/09/DSC011571-1.jpg
https://static1.pt-content.com/images/pt/2008/09/DSC01158-1.jpg
Steve68
09-27-2008, 01:04 PM
EXCELLENT!!!!! Thanks Jeff thats what I was looking for,
can I ask for one more, from under the rear end looking up, I'm trying to get an idea of clearance on rear end travel going up, thanks!!!!!
gmjj13
09-27-2008, 03:10 PM
i'll see what i can get for you tomorrow.
gmjj13
09-28-2008, 02:00 PM
this is about as good as a pic as i could get. i don't have a lift, which would have no doubt been easier. i had the wheels off working on the brakes today,
which gave a pretty good view of the exhaust. if you want to see anything else, drive on up here to sl-ocala and check it out. hope this helps. later....
https://static1.pt-content.com/images/pt/2008/09/DSC01161-1.jpg
https://static1.pt-content.com/images/pt/2008/09/DSC01162-1.jpg
ProdigyCustoms
09-28-2008, 02:38 PM
Magnaflow fit nice
Vegas69
09-28-2008, 02:49 PM
Magnaflow fit nice
I am happy with mine. Very docile cruising tone but have had many compliments already on the sound of my car. Once you get into the 4 barrels it gets noisy enough.
ProdigyCustoms
09-28-2008, 02:57 PM
Maybe he can buy your unused tailpipes Vegas!
Vegas69
09-28-2008, 03:51 PM
It's going to be tough since I gave them to ATS. Procharmo, I would make a support bracket for that pump. That will eventually cause a problem.
Steve68
09-29-2008, 09:14 AM
Thanks for who posted pics, Jeff posted exactally what I needed, making sure I had enough room from rear end travel to the tail pipes, I'm tring to tuck the system up a little more than it sits now, so I cut and rewelded the the tail pipes to bring the mufflers up a inch or 2, making sure I have enough for the X pipe with out rubbing and banging, back to the chop saw and welder after work today,
I won't try building exhaust systems on the ground again, it can be a real pain in the booty, well maybe,
71 RALLY NOVA
10-03-2008, 05:40 AM
I love the magnaflow exhaust on my 71 nova it fit great and sounds good also.
Procharmo
10-09-2008, 12:45 PM
Vegas69, would it be mounted with your bracket like the A1000 that Gmjj13 has. Gmjj13 did you mount you pump on the fuel tank??
<a href="http://i98.photobucket.com/albums/l271/choppin53/DSC01161.jpg"img>
Procharmo
10-09-2008, 01:15 PM
Gmjj13 how did you mount your A1000 to your tank without leaks etc.
Vegas69 have you any pictures of your bracket. I already have the 12AN fittings and hoses to remount the Eliminator. I just not sure about the pump being higher than the sumped outlet and causing problems!!!!
https://www.pro-touring.com/forum/showthread.php?t=43599
gmjj13
10-09-2008, 05:34 PM
its amazing what you can do with a little silly putty and some JB weld...:secret:
Vegas69
10-09-2008, 06:44 PM
I just used some 3/16 x 2" plate between my tank straps with some rubber isolators, and spacers. Clearly that won't work for you. Stock tank just isn't optimal.
gmjj13
10-09-2008, 07:04 PM
seriously though...i made a bracket from 16 gauge sheetmetal, trimmed it to fit between the stock tank straps and bolted it to the floor. i did like Vegas and used some rubber isolators between the floor and bracket and the pump and bracket.
68sixspeed
10-13-2008, 07:05 AM
Hit my pt garage; the car has the 3" magnaflow system, it needed tweaking to get it to exit right though. In stock form it wanted to exit pointed too much down and in from the quarter panel edge.
Procharmo
11-06-2008, 06:28 AM
Thanks for the info Vegas69 and Gmjj13.
I'll definaltely put that on my to do list.
Cheers.
Ranaexcavating
11-06-2008, 06:46 PM
https://static1.pt-content.com/images/pt/2008/11/IMG_7761-1.jpg
69LT1Nova
11-07-2008, 08:24 AM
Ok, so I'm fabbing up my 2.5" exhaust. These pics are great! The only question I have is how/where everybody is putting their exhaust hangers? I see most people have a hanger welded to the back side of the muff - but how does it attach to the body? Hanger to isolator to hanger welded on the body? Bolted to something? Pics would be great!
coneeng
11-16-2008, 10:29 PM
http://coneeng.com/media.html# (http://coneeng.com/media.html) Click on the link for "Impala" episode, along with the header build it also shows the 3" exhaust on the chassis. There's no body so lot's to see.
Steve68
11-24-2008, 07:23 AM
Hangers bolt to the body, off the brackets that are there,
deadjed
12-03-2008, 05:22 AM
Great pics.
67speedfreak
01-12-2009, 10:29 AM
Magnaflow fit nice
Frank,
How does the 3" kit fit on a lowered first gen?
Brian
tumper93
01-13-2009, 10:52 AM
Mine fits great and has the Hotchkis TVS on it.
