02-21-2005, 07:32 PM
check it out. this will complete your ultimate setup
adjustable A-arms: $495.00
NON adjustable A-arms: $395.00
1.25" x .120" wall seamless DOM tubing
Ball joint cups are CNC machined from 2.75" o.d. x .375" wall seamless mechanical tubing
CNC cut and formed 7 gauge spring boxes with stepped spring seat
Moog "Problem Solver" greasable ball joints (installed)
QA1 3/4" chrome-moly spherical rod ends with TeflonŽ/KevlarŽ self lubricating race
Rod ends allow additional alignment adjustability
CNC machined through sleeve and zinc coated spacers keep rod ends perfectly centered inside of the mounting brackets
Formed .125" sway bar end link mounts
Durable and brilliant powder coated finish
Fully assembled and ready to install
you can also get these in chromemoly and in either black or red. they have non adjustable versions as well which are about 100 cheaper if you guys are interested and the mods are fine with it i can always try to set up a gp with spohn
