View Full Version : Weld or Clamp Pypes X pipe
skeeters65
09-15-2008, 11:43 AM
Should I weld or clamp my X-pipe together??
What did you guys do?
critter
09-15-2008, 12:49 PM
I welded the one on my 1974 Trans Am. I'm running clamps at the pipes that go over the axle. This allows me to disconnect from the exhaust manifolds/headers and at those clamps to drop the entire front half of the system. That way I can R&R the transmission as needed. Oh, I run a single crossflow muffler from Pypes, same configuration as the factory setup. If you have true duals try using a clamp upstream from the mufflers to achieve the same thing.
gearheads78
09-15-2008, 02:37 PM
The systems I have built I weld them and make the whole center section removable with ball collectors.
Mark68
09-16-2008, 03:48 AM
On my '68 camaro I welded everything from the headers back to the mufflers. From the mufflers back, I used band clamps so I could easily remove them for maintanence or replacement. I have the Pypes 2 1/2" x-pipe system with the polished stainless violator muffers.
1969CamaroRS
09-22-2008, 06:42 PM
I have the Pypes X-pipe system as well. Also going to look at welding some pieces and clamping others so I can remove the exhaust as needed.
Steve68
09-23-2008, 03:32 AM
Welded, and band clamps on the mufflers, R&R easier,
Procharmo
09-23-2008, 02:40 PM
Clamps every where. Can you weld aluminized steel to stainless and mild steel?
Bishop73
09-23-2008, 04:20 PM
My Pypes setup is fully welded.
Tom Vogel
10-23-2008, 08:14 PM
. Can you weld aluminized steel to stainless and mild steel?[/quote]
Yes. You will loose your corosion resistance in the stainless at the weld and heat affected zones, but it will weld fine, you can use stainless rod at the stainless to mild steel interface (for tig). If you use a mig setup, check with your welding/gas supplier for the right wire for your welder.:)
Procharmo
12-02-2008, 10:29 AM
Thanks Tom, I'll get my setup welded and clamp at the mufflers/tail pipes.
Cheers.
Cam68SixSpeed
12-16-2008, 04:47 PM
If the X-Pipe is close to the transmission like most of them are you might want to use soame flanges or maybe some V-bands. Check out SPD, Burns, or deedsengineering.com
