dcozzi
09-08-2008, 09:28 PM
I have b-body spindles, Kore3 hubs, C5 rotors (13" and 1.10" thick) and radial mount caliper brackets.
The Wilwood site lists 2 different applications.
http://www.wilwood.com/Products/001-Calipers/007-SL6R14/index.asp
The builder of the custom spindles says they are set up for Wilwood 120-8000-RS and 120-8001-RS. These show they are for 1.25" thick rotors.
The 120-8079-RS and 120-8080-RS are the ones listed for 1.10" thick rotors.
Their drawing
http://www.wilwood.com/Products/001-Calipers/007-SL6R14/dwg.gif
does not differentiate between the two. Just the different mount hole offset measurements for multiple thicknesses.
THE REAL QUESTION IS: Can you use a caliper that says it is for a 1.25" rotor on a 1.10" rotor without any problems as long as the caliper is centered on the rotor?
Their drawing
