View Full Version : Can a Saginaw ps pump be converted to a remote reservoir?
parsonsj
09-02-2008, 07:53 PM
I'm using a Turn One ps pump on II Much, and I need to convert that pump to a remote reservoir.
It would seem that a press in fitting (where the integrated reservoir port is) would work well. Anybody know about anything like that?
jp
CarlC
09-02-2008, 08:25 PM
The port can be threaded to accept a straight thread o-ring/-10 fitting.
There's some pics of mine here...
https://www.pro-touring.com/forum/showthread.php?t=42290&highlight=magnuson
parsonsj
09-02-2008, 09:26 PM
Carl,
Nice! That's what I was thinking about. I took my old AGR pump apart tonight to see if machining (or welding) that port was possible. There's not a ton of metal there for machining, but it may be possible. My AGR seems to have a pressed in sleeve... I'll have a look at my TurnOne pump to see if it has a sleeve too. Cutting threads on a sleeve won't be any fun...
thanks!
jp
parsonsj
09-02-2008, 09:27 PM
Oh, and my old AGR pump was a mess. Scored base and upper pump plates along with the rotor. No wonder I had PS problems with it.
jp
Vegas69
09-03-2008, 06:34 AM
John...my pump is a type two and has a press fit fitting for the feed line. I seriously thought about tapping it so I could use an AN fitting but decided to just leave the press in fitting. It came with my March set up.
parsonsj
09-03-2008, 07:13 AM
my pump is a type two and has a press fit fitting for the feed line.Exactly! I wonder if that press fitting is available?
jp
CarlC
09-03-2008, 07:22 AM
If the housing has a sleeve in it, why not remove it and fabricate a new one to fit your needs?
Or, modify a -10AN male-XXNPT fitting by turning down the threads to make a press fit to adapt to the current port.
PS pumps do not like RPM+heat. TurnOne and Lee's both offer the TC and CB style pumps with -10AN inlets.
CarlC
09-03-2008, 07:29 AM
Carl,
jp
Tap the threads on a thick-wall tube first, then cut the O.D. Clean the housing and heat to 225* in the oven for 1/2 hour. Freeze the sleeve. It should drop in if your press fit is somewhere around 0.0003" (I'll need to check, that number is off the top of my head.)
parsonsj
09-03-2008, 07:55 AM
Carl, I love how you think. Just like me! I have to see if the Turn One pump has a sleeve. My old AGR pump is the one with the sleeve.
I ordered the tap (7/8 - 14) last night, and I'll need it either to make a fixture for my mill to turn an AN fitting or to tap the housing directly.
I'm a little reluctant to pull the actual pump out of the car right now, but maybe I should get this problem solved on my current setup before transferring it to the new one.
jp
Vegas69
09-03-2008, 08:59 AM
It wasn't a very tight press fit and was sealed with what looked like red loctite. I actually pulled it out thinking I was going to tap it. I then decided against it and put it back in with a rubber malet and red loctite. No problems so far. It's just a 90 degree elbow like you would see in a water pump. I was going to tap the pump housing and use a oring an fitting or npt with pipe dope. The opening is chamfered from memory. May want to call march, I bet the have the press fitting or know where to get it.
parsonsj
09-03-2008, 09:22 AM
It wasn't a very tight press fit and was sealed with what looked like red loctite.That's good news. This is more of a vacuum line than a pressure line anyway. So you're more worried about cavitation due to air bubbles coming in than it blowing due to pressure. I'm going to order a reservoir and if it gets here in time, I'll go to this setup for RTTH.
jp
CarlC
09-03-2008, 03:52 PM
John, I'd look hard at tapping the housing/threaded insert and using an o-ring sealed straight thread fitting. It allows you to not only use a variety of fitting types (straight, 90*, etc.) but also the ability to clock the connections.
I had the pump on mine modified by Lee's. After discussions with him about what to use, he suggested staying with the pump I had, CB, and fix it up to match the rest of the steering gear and add -10/-6 connections. Grand total? $78.
parsonsj
09-03-2008, 03:57 PM
I talked to Tony Woodward (www.woodwardsteering.com; he's the guy that made my custom rack and always takes my calls) today.
He said the same thing: they just tap it for an o-ring AN fitting. I have taps on the way, so that will be my first try.
jp
parsonsj
09-06-2008, 10:19 PM
The tap idea worked perfectly. I have my reservoir in, but I've hit a new snag: 10 AN is so big that a straight o-ring to AN fitting plus a 90 degree hose-end puts me right back where I started. I can finagle it to work, but the better solution would be a 90-degree o-ring to AN fitting.
Anybody know where I might find one on Monday for overnite shipping to me on Tuesday?
jp
Vegas69
09-06-2008, 10:26 PM
These guys are sharp with power steering. http://www.gottashow.com/ What about a banjo fitting?
hotrdblder
09-07-2008, 04:49 AM
what size john? summit has a few, http://store.summitracing.com/partdetail.asp?autofilter=1&part=EAR-949009ERL&N=700+115&autoview=sku
also napa as weatherhead type fitting for hydraulics and you can always make your own o ring fitting, just get proper thread with # 10 onother side and find o ring that fits snug. its what i do to adapt agr rack to # 6 an fitting.
parsonsj
09-07-2008, 11:49 AM
bango fittingGood idea, but I think it will have problems since the flat surface that the banjo mates to is hand filed. I don't think I could get it flat enough and square to the threads.
summit has a fewNot really... they are all on back-order. I need somebody that has them in stock and can ship them overnight! Or I won't have a car for RTTH! Thanks for looking them up, though.
jp
CarlC
09-07-2008, 12:13 PM
Find a Parker store. That's where I purchased mine.
Most any hydraulic shop should have it as well. Central Florida Hydraulics looks like they are in your neighborhood.
hotrdblder
09-07-2008, 12:24 PM
exactly, our napa's up here all have weatherhead hydraulic fittings, my bet is call a napa or even a tractor store and find out who they use for there hydraulic lines etc
Bruning Auto Design
09-07-2008, 01:29 PM
This started out as a -10 AN to 1/2" NPT stainless fitting. Tim machined the O-ring step/groove for plumbing a remote reservoir on Rob's Demon (6.1 HEMI pump) and also fabricated a hold down bracket.
CarlC
09-07-2008, 03:17 PM
That is really nice.
I always like a good bango fitting too.
parsonsj
09-07-2008, 05:21 PM
Frank Serafine is going to snag me one from a hydraulic shop near him for me. Kudos to Frank and Prodigy Customs once again!
Here's a pic of where I'm at. You can see how natural the AN-10 fitting looks, but the 90 degree hose end is still too close to the inner fenders. A 90 degree fitting and a straight hose end will solve the problem once and for all.
CarlC
09-09-2008, 09:08 PM
A nice bent-tube fitting would be better than a forged/drilled hole type in order to reduce the restriction.
Nice setup.
