View Full Version : Grommets or bulkhead connector for trunk mount battery?
Rileys68Camaro
02-19-2005, 01:40 PM
Which do you prefer and why? Is one brand better than the other for these parts?
I have the MAD Enterprises kit, and a Painless wiring harness. He uses 4(I think) guage for the battery cable, is that good? It's smaller than normal though.
EDIT: The 8ga wire is a primary power wire, not a battery cable. Mark at MAD recomends the 1/0 or similar sized for the main battery cables.
Sorry for the confusion!
But I still need opinions on gromments or bulkhead! :)
Sparky67
02-20-2005, 02:44 PM
del
Rileys68Camaro
02-20-2005, 02:59 PM
Hmm, it must be like 8 guage in the kit then. It's pretty small.
Rileys68Camaro
02-20-2005, 03:02 PM
Yep, 8ga, I wonder why he uses so small of a cable.
Sparky67
02-20-2005, 11:37 PM
del
jeffandre
02-21-2005, 01:00 AM
I used 2 O welding cable at $1/ft. It is very flexible and has handled the load fine so far. I used a bulkhead connector at the firewall after my grommet setup caused a short and a fire! I don't remember where I got the bulkhead, so try Summit/Jegs/eBay. I also used connectors that had the solder already in them, I just had to use a small propane torch to get them hot enough to install. I got them off of eBay too.
I was going to do the Optima route but chose to use 2 Odyssey PC680's instead (13# each, instantaneous cranking amps of 1360, can be stored for long periods of time, and many other great reasons). My setup is consists of the 2 small batteries installed at floor level and wired in parallel. In order to get the same from the Optima battery line I would also have to purchase 2 6-volt versions and wire them in series, and the cost was twice as much, hence the decision to get the Odyssey's. I have heard that 1 PC680 is enough for some cars, but I wanted enough juice for any occasion...
Sparky67
02-21-2005, 03:15 AM
del
JayBird
02-21-2005, 04:54 PM
Riley,
If installing a battery in trunk and bulheads at firewall, put a 200a circuit breaker between it. You can buy the kind that have a manual reset switch for $20-25. Its cheap insurance in case of a short and can use it as theft protection by manually tripping the reset swtich. Also use a 50a maxi fuse between starter and wiring harnesss like painless wiring recommends.
Dido on the quickcar cables. Very flexible.
Jay
Rileys68Camaro
02-21-2005, 06:41 PM
Graon, more wiring? My wife is going to kill me....lol
Rileys68Camaro
02-25-2005, 06:54 PM
Okay, what part numbers or what should I look for at the local Checkers or parts store or electrical store for these?
Rileys68Camaro
02-26-2005, 05:32 PM
Well, I'm a retard. Mark at MAD does NOT use 8 ga for a battery cable. It's a primary power wire hooking to the juntion block to provide a good 12 volt source.
He recomends 1/0 or similar cable for the main battery cables.
Sorry for the confusion.
Pro-touring towncar
02-28-2005, 06:22 PM
What ever you use. Always use a gromet where the wire goes through metal. It is a safety thing. I would use a good quality one. I use the good ones made by stinger they also will contract down to seal the wire.
Tim
