View Full Version : LS1 with S&P Headers.. What plug wires??
skeeters65
08-29-2008, 12:49 PM
69 Camaro with LS1 and S&P Headers..
I just installed them today and the headers touch the plug wires..
The coils are in the stock location..
What are you guys using??
juiced
08-29-2008, 01:24 PM
best bet is going to be to get some spark plug socks to match the rest of the car.
romar 02 SS
08-29-2008, 03:07 PM
If I'm not mistaken, S&P sells a set of longer/angled plug wires to clear their headers. Check the S&P catalog. Good Luck, Larry
CarlC
08-29-2008, 03:33 PM
What did S&P say about the problem?
skeeters65
08-29-2008, 07:22 PM
I just talked to them a few hours ago..
They have a set for $102.95..
More money............WTF
rickk
08-29-2008, 08:04 PM
call scott performance wire. 704 664 9700. he is first class . www.scottperformance.com (http://www.scottperformance.com)
rick k :6gears:
70bird
08-29-2008, 09:10 PM
I'm using S&P headers and am having a similar problem. After installing the first set I received, I found that the #6 tube was bent in such a way that I couldn't get the boot over the plug. I returned the pass. side and they sent me a replacement. Looked good, but after installing, now #4 is the problem though not as bad. The boot almost touches the tube.
I'm using a set of Taylor 8.2mm with straight boots #84244
skeeters65
09-01-2008, 07:35 AM
70bird
Are those wires with the straight boots working out OK for you??
70bird
09-02-2008, 06:54 AM
70bird
The wires seem to be fine. Although I don't have much running time on the motor to tell about how well they will hold up.
Here's a couple pics:
#6 plug: a little close eh?
skeeters65
09-02-2008, 11:22 AM
Thise straight plugs look just like the stock ones??
Did you say you used the S&P ones and they were no good??
70bird
09-02-2008, 04:17 PM
They are smaller in diameter than the stockers. Stock ones have the metal jacket.
Never tried the S&P wires.
