Z28a7x
08-28-2008, 02:21 PM
Mods:
10Blots Rear End without Cclips with 3.42 richmond ratio
Traction Bars By lakewood
Eaton posi lock
Competition Engineering Bolt-On Frame Connectors
T56 beef for 800LB
PST front Kit
Energy all Bushings kit
AGR Short ratio High Performance Steering Box
Koni shocks
Sway Bar: Front - 1.5"
Prothane Motion Control motor and tranny mounts
Mufflers: Dual Flow-master Delta Flow Series 40
Xpipe: Central 3" X-Pipe
B&M shift kit and mega shifter.
Eibach Springs front 1 inch drop
Eaton rear springs inch drop
10MM fuel lines with Holly Blue PUMP
4bolt 350
for now i just put in the motor Erson camshaft and Holly intake
and 4150 650CFM with K&N extreme filter.
MSD 6AL Box
MSD blaster 2
MSD pro billet dis
MSD 8.5 spark wires
Turbo motor build up
The Turbo Motor Specs:
4 bolt 350 Marin
scat 4340 crank
eagle H-beam rods
Ross custom pistons (race)
world heads 2.05 1.94 with 235CC intake runners
Crower solid roller cam
ARP bolts
CSR water pump
Holley Forceindction fuel sys
Turbontics T76
Put some Ice in my car
JVS-AVX1 HU
Infinity:
Reference Series 6-1/2" two-way component system
Reference Series REF9623I 6" x 9" three-way loudspeaker
Those spekers are the best for my opinion for Metal and Hardcore
It was better for Me than
Kappa or the JBL or Morel.
Amps:
Reference Series REF1600A 600-Watt mono Subwoofer Amplifier
Reference Series REF475A 4-Channel Full-Range Amplifier
Subs:
2x10" GTO1004D
https://static1.pt-content.com/images/pt/2008/08/IMG_0278-1.jpg
Ice sys
Eaton posi lock
T56 beef for 800LB
PST front Kit
Koni shocks
4bolt 350
MSD 6AL Box
MSD blaster 2
MSD pro billet dis
MSD 8.5 spark wires
4 bolt 350 Marin
scat 4340 crank
eagle H-beam rods
ARP bolts
CSR water pump
Turbontics T76
JVS-AVX1 HU
Infinity:
Amps:
Subs:
2x10" GTO1004D
Ice sys
