    Results 1 to 9 of 9
      Feb 2003
      Houston, TX
      Labor Day Sale - DPE Forged Wheels
      This sale will run for the entire month of September, so get your orders in!
      The group purchase is for any DPE "R-Series" wheel design. All styles are the same price. Visit www.DPE-wheels.com to see their lineup.
      Standard finish is silver or black powdercoated face with polished lips.
      18" wheel weights are typically 20-23 lbs each, depending on design.
      Backspacing/Offsets are custom made to your specs.
      Typical manufacturing times are 5-7 weeks upon order date.
      Pricing (20% off MSRP):
      18x8 $734 each
      18x9 $758 each
      18x10 $792 each
      19x8 $803 each
      19x10 $837 each
      20x8.5 $864 each
      20x10 $929 each
      Options:
      Wheels can be built with or without rivets, your choice.
      Finishes Available: silver or black (standard), polished, brushed, gunmetal gray.
      Powder coated black or silver faces (standard finish) $0
      High polished faces - add $200 per set
      Powder coated gunmetal faces - add $200 per set
      Brushed Aluminum w/ clearcoat faces - add $300 per set
      Here is how a set of 18x8 and 18x10 wheels look on a 1st gen. No mini-tubs, and stock width rear axle here:
      Co-Founder, LS1TECH.com
      www.DV8Motoring.com
      Jul 2007
      Los Angeles, CA
      Is a 12 wide wheel an option for say a mini-tubbed car? How much does widening run?
      Thanks!
      Feb 2003
      Houston, TX
      Custom widening adds $475 per wheel. Probably more cost effective to go with a 3-piece wheel.
      www.DV8Motoring.com
      California
      How much for 18" S-10's? The wheels on the M Coupe/Roadster on the homepage look AMAZING.
      Matt
      Feb 2003
      Houston, TX
      Sorry, the Signature Series is only 19" and larger.
      www.DV8Motoring.com
      California
      Quote Originally Posted by Nine Ball
      Dang...do you know if 19's would fit on a 69 Nova with AFX tall spindles and stock (for now) control arms? I'll have to photoshop the wheels onto my car to see if they'll look as good as I think, but I definitely think it'll look bitchin'. Right now I'm running 18x8 fronts and 18x9 rears. The rears fit no problem, but the fronts have like 6" of backspacing, and even with 1.5" adapters they hit the frame so I have limited steering.
      Matt
      Feb 2003
      Houston, TX
      Wheel diameter would fit, but the tire sidewall just gets thinner as you go up in diameter. Just depends on if you want to sacrifice any ride quality or aesthetics related to sidewall thickness. Just a personal preference though. What are your current size/profile tires?
      www.DV8Motoring.com
      California
      Sorry it took so long to respond, but you know how it is on Labor Day weekend.
      The fronts are 235/40ZR18's and the rears are 245/40ZR18's. I'd like to keep the ratio right now if it's possible (it looks like the sidewalls are around 2" tall on the front, but I'm not positive). I don't mind a rougher ride, but I don't want the rubberband-stretched-tire look, ya know?
      Matt
      Jul 2008
      Just to let everyone know that I am here to answer any questions you may have on our wheels along with Tony (nineball)
