View Full Version : LS1 OBD II port question
skeeters65
08-25-2008, 01:04 PM
I had my 2002 Camaro harness re-worked by wait4meperformance.com..
It did not come with an OBD II plug or Check Engine light. The wires are there though..
They said I can use any OBDII plug. Doesn anyone have one or know the GM part number??
Also as far as a Check engine Light can I use and LED light??
dhutton
08-25-2008, 01:20 PM
You can buy a pigtail version of it from several sellers on ebay.
Don
Go to a junk yard and cut the ALDL(Assembly Line Data Link, what you're calling an OBDII plug) out of any gen3/4 car. They are all the same. Yes, you can use an LED for the SES light. Make sure you put a resistor on it though as it is 12v or use a 12v LED.
skeeters65
08-26-2008, 08:05 AM
all the junk yards I called they dont want to cut the harness and destroy it..
Part number???
Bow Tie 67
08-26-2008, 08:14 AM
I used a led and it glows faintly when not lit.
Here is a link to pigtail.
http://www.eficonnection.com/eficonnection/ls1_pigtails.aspx
Somethings not completely correct with your wiring then because we use LEDs for swaps all the time no problem. I'm not good enough with electronics to know what could be the issue though.
skeeters65
08-26-2008, 05:07 PM
Thanks..
I ordered the OBDII plug from them today..
SatisTraction
08-26-2008, 05:17 PM
i connected the check engine light to the "oil" light on my stock dash. keeps it stealty :)
