dcozzi
08-23-2008, 12:01 PM
The good:
I just bought a pair of modified B-Body spindles for my second gen. They are set up nice with a Kore3 hub, C5 slotted rotors and radial mount for Wilwood 6-piston calipers.
The bad:
The hub to hub distance will be 2" shorter in front than stock. Is this is referred to as "track width". (Yeah, I'm a suspension rookie).
Can this just be fixed simply with different front rim offset? I do not like the idea of buying a new hub and using caliper bracket spacers. Horizontal spacing on a radial (vertical) mount caliper seems "wrong" to me anyway.
I also realize the additional offset of the front wheel will make the outside of the front tire hit the wheel-well sooner in tight turns.
The big question: Will the narrower hub-to-hub distance screw up my suspension geometry or have ill effects on the handling?
The bad:
