oobus
08-21-2008, 07:39 AM
Well, here is my problem:
1970 ElCamino that I just finished re-working that includes replacing the 307 with an LS1 and Auto trans, drop springs (speedway Hyperco in the back 11" single pigtail), Edelbrock upper control arms, LS1 rear brakes and I changed out the original 10 bolt open diff. for a 10 bolt with posi. Also picked up some koni shocks for the car.
I ran the car for a couple of months with the original dif. and had no issues/noises of any sort (except the cronic one-wheel spin anytime I hit the go pedal below 50mph).
So, I go to install the posi differential last night and 1st - springs are way short and will not stay in their perches, 2nd - as the suspension trys drop to the bottom of it's travel, it jams the driveshaft all the way into the transmission. I think that the drive shaft did the same thing with the last rear end, but, the airshocks limited the extended travel so it would not bind - not really sure though.
Questions:
1. Does anybody know if this driveshaft issue is normal?
2. How did everyone with lowering springs keep them from falling out during "Bo Duke" suspension unloading?
I think if I build some travel limiting cables, it may solve all my problems, but, I'm new to this and don't want to screw up my 90% finished ride! Thanks for the help guys.
Questions:
