Flash68
08-21-2008, 02:30 AM
Hey guys,
I used the search function and many are running the fuel pump inside the tank, but wanted to see if this set up is okay to run.
otor is a Procharged 406 small block with Holley Stealth Ram, FAST EFI, 75 lb injectors, and about 750hp.
A1000 fuel pump mounted externally
new stock fuel tank with baffling installed and a return line
I think this is going to work, although not as awesome as Rick's Stainless or a Rock Valley tank, but it should be fine right?
thanks in advance
thanks in advance
