View Full Version : A1000, stock fuel tank w/ baffling okay?
Flash68
08-21-2008, 02:30 AM
Hey guys,
I used the search function and many are running the fuel pump inside the tank, but wanted to see if this set up is okay to run.
otor is a Procharged 406 small block with Holley Stealth Ram, FAST EFI, 75 lb injectors, and about 750hp.
A1000 fuel pump mounted externally
new stock fuel tank with baffling installed and a return line
I think this is going to work, although not as awesome as Rick's Stainless or a Rock Valley tank, but it should be fine right?
thanks in advance
1969CamaroRS
08-21-2008, 03:05 PM
I found this reference useful for Aeromotive:
EFI (http://www.aeromotiveinc.com/d_systems.php?systemdisplay=efi)
Carb (http://www.aeromotiveinc.com/d_systems.php?systemdisplay=carb)
Hope this helps.
Flash68
08-21-2008, 03:31 PM
Hope this helps.
Yes, that does help. Thank you.
I guess I am wondering why many mount the pump internally. Is it for primarily for noise control?
Also, if something goes wrong with the pump isn't it a pain to get at it if it's internal?
86Cutlass383SR
08-21-2008, 06:22 PM
Noise control and longevity. They run cooler in-tank due to the fuel. They can be a pain to access internally ... unless you fashion an access panel or removable cover.
Doug
Flash68
08-21-2008, 08:17 PM
Doug
Makes sense. Thanks Doug.
