with tuning leafs would keep up, however doing a rear susp would make if far easier to do,
sounds like you have the front taken care of, I have a new tq arm rear that I just got done testing, was designed by Katz and has the fewest compromises out there, in basic form its non adjustable, then we have a road race option for adjust ability on different tracks, it allows you to loosen the car up for slower tighter tracks, then allows you to tighten the rear up for tracks like mosport, mont tremblant, etc
https://static1.pt-content.com/images/pt/2008/08/IMG_1662-1.jpg
https://static1.pt-content.com/images/pt/2008/08/IMG_1657-1.jpg
https://static1.pt-content.com/images/pt/2008/08/200808040694-1.jpg
https://static1.pt-content.com/images/pt/2008/08/IMG_1674-1.jpg
lastly you get this very well designed tq arm susp(3 link), and you do not need to cut the car in half, front mount bolts between subframe legs,has a nhra approved drive shaft hoop,lower links use front spring pocket mounts,the rear upper shock cross member welds into place, as well as phb mount with 45º brace, and you can either weld your own axle brackets in place or buy a pre welded axle housing.Bilsteins come non adjustable in the basic package, with 6 way adjustable's being an option, we worked with the motorsports division engineer to get our valving where we wanted it.
also look into my front clip, as the front and rear were designed together as a package, not individual systems. The front also comes with bilstein aluminum coil overs.
call or email anytime
[email protected]
