View Full Version : For those of you with the BRP power rack and pinion
Les69
08-15-2008, 09:29 AM
I'm pretty sure this question has popped up somewhere before but I couldn't find it so.. I'm asking! I was thinking about picking the power rack and pinion up for my subframe since I wouldn't have to mod the LS1 F body oil pan. I was curious though, what exactly needs to be modified on the subframe to add the front mounted power rack and pinion?
TitoJones
08-15-2008, 09:55 AM
All sorts of stuff. You have to cut a deep trench out for the steering linkage to go to the column, and relocate the sway bar to the rear. The issue I had with the kit was putting the engine that far forward, and the fact that the sway bar was lower than the frame made it a debris catcher when driving.
Tyler
SatisTraction
08-15-2008, 10:36 AM
i would look into other options
dhutton
08-15-2008, 03:08 PM
Even Phil Brewer has given up on that conversion. He's now selling mounts with GM conversion pans.
I'm sure it seemed like a good idea at the time but that was a long time ago and there are much better options now.
Don
Les69
08-15-2008, 09:49 PM
thanks for the input. i'll definitely have to check out my other options then. sounds like more work than i wanna deal with.
