View Full Version : Best practices for adding flattening agent
scogin918
08-15-2008, 06:28 AM
What are/is the best method(s) for adding a flattening agent to paint to ensure consistency? Do you guys do it by weight or by measuring the fluid?. I am planning on using the Sherwin Williams Dimensions single stage gloss on the car but with a flattening agent to achieve a satin finish. I want to do the firewall and trunk area first then cut in/jamb the car and paint the body a little later.
Shoot test panels. Start at 5%, then 10% etc...
Label each panel and choose the one that looks the closest to the finish you desire.
I usually use HOK and use 8/2/2/1.
Clear/hardner/reducer/flatner
Alchemist
08-25-2008, 07:03 PM
Here are a few previous threads discussing the satin black look!
https://www.pro-touring.com/forum/showthread.php?t=45283&highlight=SEM+Hot+Rod+Black
https://www.pro-touring.com/forum/showthread.php?t=44637&highlight=SEM+Hot+Rod+Black
https://www.pro-touring.com/forum/showthread.php?t=43535&highlight=SEM+Hot+Rod+Black
