Gandalf
08-08-2008, 09:31 AM
I found a wheel design that I really like the look of. They are aftermarket wheels for Mercedes and I'd like to see if I can fit them on a 69 Camaro. They are 18x8.5". I emailed the seller and he says they are available in 30mm and 45mm offsets. I know I'll need to deal with the bolt pattern differences which seems simple enough but the other width/fitment issues boggle my mind. There are so many calculations and metric-std conversiona that it makes my head hurt. I don't mind rolling the lip on the rear.
Assuming my 1st gen is still running stock width rear and front suspension - can I make these wheels work on a 69 Camaro?
What is the widest tire I can run on an 8.5" rim?
I'd like to lower the stance of the car also - so the rear will be running a G-Bar and I may use the AM front-end (which I know will change the offsets and such yet again).
Thanks for any help.
G
G
