View Full Version : LS67 Project "Overclock"
SSable
08-04-2008, 09:44 PM
Hello all,
Introducing "OveŽŠlock" Since I'm into computers. (Former 4 Years and Couting)
Definition for all those not into computers! (http://dictionary.reference.com/search?q=overclock)
I have been on the board for some time and never posted anything, just reading and learning. I thought it was time to chip in and introduce myself and my 67 Camaro.
I have painstakingly assembled the car from a complete tear down to what it is today in my garage.
https://static1.pt-content.com/images/pt/2008/08/85-1.jpg
Paint is done and finishing AC and steering.
https://static1.pt-content.com/images/pt/2008/08/52-1.jpg
https://static1.pt-content.com/images/pt/2008/08/21-1.jpg
BossaNova
08-05-2008, 03:36 AM
Rear looks good. Got anymore pics?
SSable
08-05-2008, 05:02 AM
should have some more shortly!
https://static1.pt-content.com/images/pt/2008/08/86-1.jpg
https://static1.pt-content.com/images/pt/2008/08/87-1.jpg
https://static1.pt-content.com/images/pt/2008/08/88-1.jpg
https://static1.pt-content.com/images/pt/2008/08/89-1.jpg
https://static1.pt-content.com/images/pt/2008/08/90-1.jpg
https://static1.pt-content.com/images/pt/2008/08/91-1.jpg
https://static1.pt-content.com/images/pt/2008/08/92-1.jpg
marc_b
08-06-2008, 10:03 PM
nice from the rear. tire specs?
yup, that rear looks the business!
don't be a tease, we're gonna need more pics.
what color are you planning on?
Motown 454
08-07-2008, 04:59 PM
Lets see some more !
SSable
02-11-2009, 05:45 PM
****UPDATE****
Well after many months of planning I finally bought a motor and installed it. I would have had it in sooner, but forum member (Saunacrank) ripped me off from a BRP install kit So I had to order one from BRP.
Rearend: Moser M9 55" powerdercoated. Installed Moser 31 nodular 3.90 True track and supports. Bear 13" sports slow it down. Air-Ride rear with coil overs.
Front end: GW uppers and QA1 coil overs, Del-a-lum arms and body mounts. All items powder coated, including front clip and inner fenders.
Body: Complete tear-down, sand blasted, POR15 under and over.
Engine: Ls2 with LS3 topend. TSP Heads, SS valves and LS7 components. 228R-112 Cam, LH8 pan setup. T56 from GTO. Much more!
More updates coming soon! but here are some pics.
https://static1.pt-content.com/images/pt/2009/02/93-1.jpg
https://static1.pt-content.com/images/pt/2009/02/27-1.jpg
https://static1.pt-content.com/images/pt/2009/02/28-1.jpg
https://static1.pt-content.com/images/pt/2009/02/94-1.jpg
carguy502
02-11-2009, 06:05 PM
That is so hot. Stock subframe? if so how does that rack clear the pan?
SSable
02-11-2009, 06:15 PM
Thanks! Rack clears with about 1.5" spare. However you will not be able to install the motor with tranny attached with it in.:)
SSable
02-11-2009, 06:18 PM
Yes, Stock sub frame that was cleaned up and seam welded.
meenaggie
02-11-2009, 06:20 PM
Looks nice. What is the ground clearance with the LH8 pan? I am about to purchase a pan for my LS2.
SSable
02-11-2009, 06:43 PM
Depends on the setup you have up front, but take note the pan sticks out about 2" below the cross member. I'm going to have a skid plate made to help protect it.
craigs73
02-11-2009, 09:53 PM
Hello all,
Over the past couple years I have slowly and painstakingly assembled the car from a complete tear down to what it is today. My most recent purchase was a complete rear and g-bar setup from GP Superstore and they have been helpful and very informative. Just bought a rear brake setup to finish it off and it should be off for paint.
More pics soon!
sounds like how my project will be. i also got my g-bar from frank at gp superstore he is a really good guy to do business:1st:
Motown 454
02-12-2009, 01:07 PM
SSable sweet looking motor. I'm wishing I went LS myself.
SSable
02-12-2009, 04:34 PM
thank you!
BMF Machine
02-12-2009, 05:34 PM
That rear end looks AbsoFricKinLutelY SicKasHeLL!
SSable
03-07-2009, 09:15 PM
Project updates.
I have been hooking up the Hydroboost, radiator and gastank. finished the motor for now. I was able to get with Mast Motorsports and received one of the first sets of L76 fuel rails. I promptly order all pluming parts and got everything installed.
I plumed 8AN all the way back for future builds like force induction.
Radiator- I order the Entropy setup for Automatic. I really impressed with the build quality and workmanship. All the bolts that hold the fan setup together use the same Stainless hardware that I'm using on the engine, great product for the money. I'm using the Trans cooler to cool my PS and Hydroboost setup. With the Entropy radiator, the transcooler is located on the drivers side so it makes it easy to plumb in.
More to come!
https://static1.pt-content.com/images/pt/2009/03/29-1.jpg
https://static1.pt-content.com/images/pt/2009/03/30-1.jpg
1971CHEVELLE
03-08-2009, 08:58 AM
Wow awesome......:1st:
icebird84
03-08-2009, 10:32 AM
Wow hot
SSable
03-08-2009, 02:07 PM
thank you! I'm hopefull I can get this running next month. The computer has been shipped off for programing. Next Paint!
SSable
03-15-2009, 10:20 AM
Stuff is coming together, I installed the Enropy Radiator, Spectra Gas tank and other parts. One of my favorites is the Polished and ported TB from Janzter, I took awhile but I got it the other day and installed it with the 1- 1/8 Willwod master cylinder. Finshed up some plumbing, but have more to go.
Motown 454
03-15-2009, 11:07 AM
You do nice work it looks great. Who's motor mout kit is that. and how much did it push the engiine back ?
SSable
03-15-2009, 12:30 PM
It's BRP's, How much from stock I'm not exactly sure, but it's close to it. It's not as far back as the ATS kits I think. My only concern is that the Oil pan clears the rack and Pinion and leaves sufficient clearance for the intake/MAF setup and Fans.
Dougs67camaro
03-15-2009, 02:17 PM
Clean!
73supreme455
03-15-2009, 09:19 PM
Lookin good!!
Flash68
03-15-2009, 11:03 PM
Sweet project! What wheels and tires did you end up going with?
SSable
03-16-2009, 05:39 AM
I havn't decited yet, but I will probably go with what you did on your 68 if available.:)
SSable
01-17-2010, 06:08 PM
Project update - Driven down the driveway on first voyage! might not seem alot, but after 6 years of downtime it s a great feeling.
http://www.facebook.com/v/137869422621
SSable
01-07-2011, 08:30 AM
It's been a year since I posted any update! It was a tough year, but things are looking up! PAINT as begun! We have taken the car apart and focused on each piece for perfection. Our first assembly was to get the lines perfect and even throughout. Now each piece is sprayed with 3 prime build coats with blocking in between and a dark blue seal coat before the base black. we are consistent at 3 base and 3 clear coats. We have done some cutting and buffing, but we are waiting for finally assembly.
Ron.in.SoCal
01-07-2011, 12:24 PM
Looks pretty! Love the black on 67/68's...
David Sloan
01-07-2011, 02:06 PM
Nice paint work/body work.
Steve68
01-07-2011, 04:51 PM
Great pics, more.....
SSable
01-10-2011, 06:38 AM
Couple more shots! we are about to start on the body. Going to take some time!
https://static1.pt-content.com/images/pt/2011/01/1-2.jpg
https://static1.pt-content.com/images/pt/2011/01/2-1.jpg
https://static1.pt-content.com/images/pt/2011/01/3-1.jpg
https://static1.pt-content.com/images/pt/2011/01/4-1.jpg
https://static1.pt-content.com/images/pt/2011/01/5-1.jpg
Ron.in.SoCal
01-10-2011, 09:05 AM
I recognize those wheels!
69fbodyproject
01-10-2011, 02:28 PM
Whos setuo did you use for mounting the coil packs?
SSable
01-10-2011, 09:57 PM
nasty Performace
SSable
04-13-2011, 09:10 AM
Progress is being made everyday! All parts that can be taken off the main body have been painted. Now too the most difficult! all metal imperfections have been accounted for and now it's to finishing details in the lines and flow. Several blocking sessions and re-coats expected. Almost there! Vintage Air and interior ready to install.
https://static1.pt-content.com/images/pt/2011/04/6-1.jpg
https://static1.pt-content.com/images/pt/2011/04/7-1.jpg
https://static1.pt-content.com/images/pt/2011/04/8-1.jpg
https://static1.pt-content.com/images/pt/2011/04/9-1.jpg
SSable
04-19-2011, 04:56 AM
It's hard to believe but this car has been in build mode for 8 years. Took 3 years off getting my family started and moving from house too house. With that in mind, it's very easy to forget every detail you have done to the car, including the first attempts at body work and patching. Well the old work showed it's ugly head with some long disgusting stress cracks and it left me scratching my head... what the hell was I thinking? The car is in it's final primer coats and it's unconventional to take so many steps back this late in the game... but it is what it is. It needs to be right! Whats an extra couple hours???
https://static1.pt-content.com/images/pt/2011/04/10-1.jpg
https://static1.pt-content.com/images/pt/2011/04/11-1.jpg
https://static1.pt-content.com/images/pt/2011/04/12-1.jpg
https://static1.pt-content.com/images/pt/2011/04/13-1.jpg
absintheisfun
04-19-2011, 07:12 PM
I feel your pain on the long builds! And I can second the head scratching moment when you come across your earlier work.
That black looks amazing!
CruizinKev
04-20-2011, 01:47 AM
sweet nice wheels! looks very good so far!
SSable
05-17-2011, 05:27 AM
IT'S ALL BLACK! Finally after all these years looking at gray and rose it's all one color. now the hard stuff with sanding and buffing. My painter and I have had some interesting problems with PPG paints and dimples. PPG put out a product to limit them but they still occur. Its only in the clear not the base or seal coats and they start to form about 10-20 minutes after spraying. We end up putting a drop of clear in the dimple and sanding it, but it's still a pain! The below pictures are raw and one of them is the sail panel passinger side that has got some sanding love and buffing. More pictures to come!
https://static1.pt-content.com/images/pt/2011/05/14-1.jpg
https://static1.pt-content.com/images/pt/2011/05/15-1.jpg
https://static1.pt-content.com/images/pt/2011/05/16-1.jpg
https://static1.pt-content.com/images/pt/2011/05/17-1.jpg
https://static1.pt-content.com/images/pt/2011/05/18-1.jpg
https://static1.pt-content.com/images/pt/2011/05/19-1.jpg
https://static1.pt-content.com/images/pt/2011/05/20-1.jpg
Dons67
05-17-2011, 05:47 AM
very nice -- somethings are worth the wait!
SSable
05-17-2011, 03:23 PM
https://static1.pt-content.com/images/pt/2011/05/22-1.jpg
https://static1.pt-content.com/images/pt/2011/05/23-1.jpg
boos2
05-17-2011, 05:39 PM
I'm new to this board because this is my buddy's car. Justin has been working a long time on this thing, taking it slowly and doing it right. I just wanted to say congratulations, the car is finally coming together. You've worked very hard on it and it looks great. Proud to say I've shed some knuckle skin on it as well as getting a transmission fluid bath lying underneath. Can't wait to see this thing hit the road.
Mike
SSable
05-17-2011, 06:38 PM
Thanks for all your help bro!
Mike
SSable
05-17-2011, 06:49 PM
More pic, much earlier in the process!
https://static1.pt-content.com/images/pt/2011/05/24-1.jpg
https://static1.pt-content.com/images/pt/2011/05/25-1.jpg
https://static1.pt-content.com/images/pt/2011/05/26-1.jpg
robertjra
05-17-2011, 08:16 PM
strate love the m9, super sick!!!!!!! cant wate till i that close im into mine 4 years now and it looks like 4 more...... will it ever end? you are doing some great work builds like this make me want to get off my butt and work on my car thanks for puttin this on!!!
craigs73
the paint looks great!! did you guys paint the car in your garage? looks like you raised the garage door and had filters attached to cardboard maybe? how did you circulate the air? keep up the great work
SSable
05-17-2011, 08:21 PM
It will end! just get off your couch and have some fun.
SSable
05-17-2011, 08:27 PM
Yes in the garage. my painter has a huge blower fan with filters on it that pulls air our the opposite side through the wall and vented out.(you can see it in the first color black pitcure with boxes on the top.) he also has a wall curtain to help decrease area for better CFM. Works well and with great prep...flawless.
robertjra
05-17-2011, 08:29 PM
i know!!! i do this for a living 10-12 hr a day so when it comes to my own car it just looks like too much work but if i get two days in a row off that's when i get stuff done oh ya and the $$ I'm going to do the m9 with torque arm cant wait!!! what axle length did you go with from rear axle seal to axle seal? and the tires are those 335?
craigs73
05-17-2011, 08:30 PM
i see it now thanks again the car looks great
SSable
05-17-2011, 09:00 PM
I fully understand! I work on computers all day and the last thing i want to do is work on my own. I know the flange to flang length is @ 55". The Pilot sports are 345's.
https://static1.pt-content.com/images/pt/2011/05/31-1.jpg
robertjra
05-18-2011, 07:05 PM
hay thanks your car is killer good work!!! i cant wate till my day off so i can work on my 69.
SSable
05-18-2011, 07:09 PM
Thanks Robert. hope you finish soon!
SSable
05-19-2011, 05:10 PM
I got the VA today and looking forward to install once the car is back from paint! Parts piling up!
https://static1.pt-content.com/images/pt/2011/05/32-1.jpg
SSable
05-21-2011, 07:15 PM
Brief check of history!. Back in the day when i first unloaded the camaro for the first time, I had large assperations... ever-changing thoughts on how i wanted my first year camaro to be. I knew in the elite class of restores it need to be strait and with crisp lines. The funny thing after 8 years of building, I never really understood the complexity and determination it took to make it right, no matter the fabrication that occurred. Think back, remember the car commercial when rolling a ball bearing down a Lexus hood gap line was considered a feat of engineering! after thinking a little more... I realized that it's the conception of what you feel is right. Back in 2003 here is my vision and it's carried on to today. What do you see?
https://static1.pt-content.com/images/pt/2011/05/33-1.jpg
https://static1.pt-content.com/images/pt/2011/05/34-1.jpg
https://static1.pt-content.com/images/pt/2011/05/35-1.jpg
https://static1.pt-content.com/images/pt/2011/05/36-1.jpg
https://static1.pt-content.com/images/pt/2011/05/37-1.jpg
I see a badass car. What do you see?
SSable
05-22-2011, 06:34 PM
Thanks all!
Updates from today. We re-cleared the car again due to some imperfections. Now the sanding and buffing in full force!
https://static1.pt-content.com/images/pt/2011/05/39-1.jpg
https://static1.pt-content.com/images/pt/2011/05/38-1.jpg
BulldawgMusclecars
05-22-2011, 07:09 PM
Looking great!
CruizinKev
05-22-2011, 07:31 PM
oh yeah very nice!
Rybar
05-24-2011, 09:50 AM
Car is looking great, keep the updates coming.
SSable
05-31-2011, 10:56 AM
Progress over the holiday! taking time and doing it right. My painter is a perfectionist, so it will be perfect!
https://static1.pt-content.com/images/pt/2011/05/40-1.jpg
https://static1.pt-content.com/images/pt/2011/05/41-1.jpg
https://static1.pt-content.com/images/pt/2011/05/42-1.jpg
https://static1.pt-content.com/images/pt/2011/05/43-1.jpg
https://static1.pt-content.com/images/pt/2011/05/44-1.jpg
boos2
05-31-2011, 02:29 PM
looking good my friend, can't wait to help you button it up
RicerwannaB
05-31-2011, 03:39 PM
Looking good man!
SSable
05-31-2011, 05:35 PM
thanks guys! get reay mike!
Vicinity
05-31-2011, 05:39 PM
I really like this build, I can't believe I haven't commented before. Very well done. Also interesting to see ten spoke SS wheels on a 1st gen!
SSable
05-31-2011, 06:08 PM
Thanks Dan. Been a long time build. You should see the 3 inch spacers needed to bolt wheels on!
SSable
06-15-2011, 07:45 AM
Paint update. We have completed painting and finalizing sanding and buffing. Overclocked will return home and get some AC love from Vintage Air and final assembly. Then Interior work can begin!
https://static1.pt-content.com/images/pt/2011/06/45-1.jpg
https://static1.pt-content.com/images/pt/2011/06/46-1.jpg
https://static1.pt-content.com/images/pt/2011/06/47-1.jpg
https://static1.pt-content.com/images/pt/2011/06/48-1.jpg
LV42DAY
06-16-2011, 09:51 PM
thats beautiful. looking forward to seeing it come together
SSable
06-20-2011, 07:16 AM
Overclocked is home!
After several months in the paint shop getting it's beauty treatment, its founds its way home over the weekend. Perfect timing for fathers day! Now the fun stuff starts. Vintage Air and firewall items, interior etc! More updates on the way!
https://static1.pt-content.com/images/pt/2011/06/50-1.jpg
https://static1.pt-content.com/images/pt/2011/06/49-1.jpg
https://static1.pt-content.com/images/pt/2011/06/51-1.jpg
CruizinKev
06-20-2011, 08:09 AM
oh WOW!!!
WICKED_SS
06-20-2011, 04:58 PM
Very nice! cant wait to see more pics going to gether!
SSable
06-28-2011, 06:19 PM
Project update-
After several months in paint...much to do. Cleaning and re-polishing oxidated metals and dust. I have spent the last couple weekends cleaning and painting the trunk and internal panels. The vintage air install has started and bulkhead installed. Coachworks gas cap and rear taillights installed. just need to finalize steering linkage and fab up brackets for AC compressor before front sheetmetal can even think of going on. More coming this weekend!
https://static1.pt-content.com/images/pt/2011/06/53-1.jpg
https://static1.pt-content.com/images/pt/2011/06/54-2.jpg
https://static1.pt-content.com/images/pt/2011/06/55-2.jpg
https://static1.pt-content.com/images/pt/2011/06/56-2.jpg
https://static1.pt-content.com/images/pt/2011/06/57-2.jpg
icebird84
06-28-2011, 06:28 PM
looking good
Motown 454
06-28-2011, 07:49 PM
Very Nice, it looks awesome!
SSable
06-28-2011, 08:00 PM
thanks guys! cant wait to get it fully assembled. stay tuned.
SSable
07-03-2011, 08:14 AM
Have a full day of stuff to do. last couple days finished the hard wiring for the battery in the trunk and master cutoff. I found out that my fuel pump went south while attempting to start it, so new tank is in the works. I was planning on ordering the flush mount windows, but that will need to wait. Friday I dropped off the back seats to have recovered, depending on the quality of work will determines if i take them the front seats. Still have some cleaning to do, but the goal this weekend is to have the steering finished and AC brackets fabed up. Pictures tonight!
srh3trinity
07-03-2011, 11:34 AM
I am liking the look of this one. The wheels look perfect.
icemanrd19
07-03-2011, 04:44 PM
Did you paint the gas cap or just order the black anodized one?
meenaggie
07-03-2011, 06:28 PM
Looks like the black anodized piece from Precisions Coachworks (a.k.a. Ride Tech) for the 67-68 camaro. (I have the same gas cap.)
SSable
07-03-2011, 07:11 PM
Thank you. cant wait to get the front assembled!
SSable
07-04-2011, 08:25 PM
Holiday weekend update.
To start out... kind of disappointed that some vendors didn't care to have an Independence Day sale this week. Would have been nice since have much to order. Just saying. :usa:
I spent some time finishing the trunk still have some minor wiring to do but it's done. I found some areas of minor over-spray on the frame and buffed them out, gotta love powder coating! spent a couple hours on the AC compressor mount and got it to fit! I ended up having to mod the stock mount and build my own brackets to draw it closer to the block. I was first concerned about bolt alignments and using them as guide to get the right pitch for the compressor then also keep and eye on the centerline for the crank pulley and refrigerant ports. It took several spot welds and re-spot welds to get it right. The top bracket is rough in the pictures but I'm really happy with the look. I can't stand the compressor or alternator over the valve cover. Pictures below! Happy 4th everyone! 235 years!!!
https://static1.pt-content.com/images/pt/2011/07/58-1.jpg
https://static1.pt-content.com/images/pt/2011/07/59-1.jpg
https://static1.pt-content.com/images/pt/2011/07/60-1.jpg
https://static1.pt-content.com/images/pt/2011/07/61-1.jpg
https://static1.pt-content.com/images/pt/2011/07/62-1.jpg
https://static1.pt-content.com/images/pt/2011/07/63-1.jpg
SSable
07-09-2011, 05:53 AM
Plans for the weekend are obvious! finish the work on the AC bracket and paint it. I tried to start the car and found out the fuel pump is bad. Did some looking around and found several posts about the Spectra tanks fuel issues. When this tank first came out back in 2008 it was a great alternative to a higher end units like Ricks or Rock Valley. Well after several years, issues with pump came forward and now its not such a good fit for my ride. The replacement pumps are rated too low for the amount of flow I need so I will replace the pump and put it up for sale if anyone wants it. So... time to bite the bullet and bone up for a really nice tank that will support around 600HP. I ended up calling Hector @ Ricks tanks for his opinion and we agreed on the new VaporWorx setup. I did some research before calling about this setp and it looks trick, plus it only needs one line to the fuel rails. NICE! Needless to say its on the way. I also called Vintage Air and ordered all the AC lines needed to finish the engine compartment. So my goal this weekend is to finish detailing the engine, mount the steering column and fix the linkage to the rack and pinion, then maybe hange some sheet metal next weekend! More to come with the some pictures.
Motown 454
07-09-2011, 11:01 AM
Its looking good.
SSable
07-10-2011, 06:31 PM
Well you know how it goes sometimes, you have a plan and it never works out. I did however get allot done, just added a few things to the list.
This took some time but it looks great! Polished everything that oxidized back to its original look. just a note for those about to paint and have aluminum, etc around make sure you take some time covering it up and sealing it the best you can. Todays paints are very caustic and the fumes will make quick work oxidizing your bullet. (Note the AC compressor bracket, DONE!)
https://static1.pt-content.com/images/pt/2011/07/64-1.jpg
Took some time and blew apart the alternator for paint.
https://static1.pt-content.com/images/pt/2011/07/65-1.jpg
Thats it for today.
SSable
07-14-2011, 09:02 PM
Good news and Bad. The bad first, still working on the AC lines. Waiting a few parts missed in the order for vintage air. Looked at the steering linkage, but have yet touched it. The good, my gas tank is on the way and I ordered all new windows, including a set of flush mounts. Can't wait to put those in!
https://static1.pt-content.com/images/pt/2010/07/DSC03228-1.jpg
https://static1.pt-content.com/images/pt/2010/07/DSC03223-1.jpg
I will finish the steering this weekend and wrap up the wiring for the AC under the hood. If all goes well hang some sheet metal.
SSable
07-16-2011, 09:08 PM
Steering completed today and finalizing some wiring for the AC. I hung the passenger door and front fender today. woohoo!! The door needs to move forward about 1/8" to be perfect. The line are perfect and paint is outstanding. I will be posting pictures tomorrow.
SSable
07-17-2011, 08:40 PM
Update!
The tires have hit the ground with some major Sheet metal attached. Enough talk...just pictures. :)
https://static1.pt-content.com/images/pt/2011/07/66-1.jpg
https://static1.pt-content.com/images/pt/2011/07/67-1.jpg
https://static1.pt-content.com/images/pt/2011/07/68-1.jpg
https://static1.pt-content.com/images/pt/2011/07/69-1.jpg
https://static1.pt-content.com/images/pt/2011/07/70-1.jpg
Head panel and lower valance up next!
Rybar
07-18-2011, 03:55 PM
Looks good, I recognize the wheels and tires.
SSable
07-18-2011, 07:34 PM
Thanks, Yea several people have mentioned that. I love the look of them with black.
Motown 454
07-18-2011, 09:58 PM
Everything looks great ! The wheels go perfect with the color. Sweet Ride.
SSable
07-19-2011, 08:54 PM
Thanks Wayne!
SSable
07-19-2011, 08:57 PM
I picked up my GTO seats today from the upholstry shop. they did a great job. should have the rears done tomorrow. Did some wiring tonight for the AC and looking to use the engine harness AC request line.
https://static1.pt-content.com/images/pt/2011/07/71-1.jpg
johnny68
07-20-2011, 07:24 AM
looking great im curious to see how your windows turn out. did you have to do any frame mods. for the flush mount windows?
john
SSable
07-20-2011, 08:25 AM
john
Thanks John, According to many others that have done the installs as well as the manufacture no modifications are needed. I'm curious how it's going to fit with transition from pillar to cowl, each car is differant. The picture above is not ideal.
SSable
07-22-2011, 06:09 AM
Up until 1AM realigning the drivers side door and fender. Didn't like the gaps. I remember aligning this side during fitment with the same problems. set to finish up on the front sheet metal and start working on the grill. Final buff and polish next weekend!
SSable
07-26-2011, 09:32 PM
So much to do It's just daunting! Working on it as i can. I received the flush Mount windows today and kind of disappointed that not all of the kit was there. Check on the Glass and sealant but no foam strips, trim or instructions. I'm not really the one to complain, but spending the amount of money I did for these I would expect everything to show up. Carpet arrived and have made several stops at Camaro Concepts for misc items. I'm expecting ricks tank to be here Friday as well as all the fittings and filters needed. Plans to fire it up again this weekend! Finish wiring in the front grill and mounting an Anvil CF front spoiler.
Need some suggestions on an HID setup. Fesler?
CarlC
07-26-2011, 10:23 PM
No external fuel filter needed for that setup. The filter is in the module. Just flush the line to the fuel rail before final connection.
The bodywork and craftsmanship is outstanding!
SSable
07-27-2011, 06:05 AM
Thanks Carl and thanks for the harness setup for the new tank! I thought it only had 10 Micron filter for pickups? Please let me know and I will send some stuff back. I purchased a 100 Micron external setup.
SSable
07-27-2011, 09:40 AM
I stand corrected. it comes in a separate box via USPS. Talked to Robert at Class Auto Glass Innovations and filled me in. Nice guy and very helpful. Thanks!
CarlC
07-27-2011, 08:36 PM
The filter that is in the module is the only one that is installed in both the Camaro and the CTS-V. No other external filters are used, and GM offers a 100,000 mile warranty on these new cars. They are a heck of a lot smarter than I am so I'll plagiarize their work. I'd send the other filters back. Just be sure to flush the line before final attachment.
The corner pickups use a screen that is used to close a valve when fuel sloshes away. All fuel from the corner pickups goes into the module reservoir where it is filtered before entering the pump. The filter is mounted on the the pump inlet so there is no way that any contamination sucked up by the corner pickups can get in.
FRENCHBLUE72
07-29-2011, 08:42 AM
Awesome build you have going here..
Dobster
07-29-2011, 05:32 PM
I cant wait to see the glass installed.
paint work just amazing..
Keep at it man...
SSable
07-30-2011, 04:21 AM
Thanks Guys!
SSable
07-30-2011, 04:22 AM
Great info! thank you for your help Carl. Parts going back.
eric1967
07-30-2011, 04:59 AM
Car is looking great. You are getting near the end. Have you had the seats in it yet? Just wondering how they fit in a first gen. Thanks eric
SSable
07-30-2011, 07:59 PM
Yes front seats are done. welded up some brackets to mount them as low as I could with the power options. The rears will take much work as they very large. Started on them today.
SSable
07-31-2011, 04:54 AM
More progress. I was able to complete putting together the front end and make some final changes, wiring is done for the most part waiting on headlights and parking lights. Changes included new Anvil parts to spruce up the engine compartment and "OverŽŠlock" image. I had to move the radiator back about 3/8 to allow the closeout cover to fit. I'm really happy with this piece and the lower spoiler as it should also help focus the air through the core support. Working on rear seats and then dash wiring. Most of the wiring is in place and just needs to organized and routed correctly. AC vent hoses will also need to be installed. I received electric life's power windows setup earlier in the week so windows are coming up. I will get the new Gas tank and RB hood hinges/door handles next week to finish the exterior. Picture of the seat progress tonight.
https://static1.pt-content.com/images/pt/2011/07/72-1.jpg
https://static1.pt-content.com/images/pt/2011/07/73-1.jpg
Motown 454
07-31-2011, 03:11 PM
Sweet!
SSable
07-31-2011, 07:12 PM
Todays update. GTO rear seat install
Moved to the rear seats today. I know the GTO seat are huge but the backs are bigger! The keys are to be able to remove a couple inches from the back of the bottom seat and several inches from the bottom of the top to make it look proportional but usable. I have no intentions in taking 4 adults for a cruse at the same time. However for a few kiddos or the mother in-law :naughty:, no problem. I want to use the stock mounts and bolt locations so these can be taken out quickly when needed. lets roll with the pics.
PS. Removing the seat skeletons is easy on these seats. I was able to modify the existing framing without major modification to the overall structure.
https://static1.pt-content.com/images/pt/2011/08/74-1.jpg
https://static1.pt-content.com/images/pt/2011/08/75-1.jpg
https://static1.pt-content.com/images/pt/2011/08/76-1.jpg
https://static1.pt-content.com/images/pt/2011/08/77-1.jpg
https://static1.pt-content.com/images/pt/2011/08/78-1.jpg
Size differances of backs.
https://static1.pt-content.com/images/pt/2011/08/79-1.jpg
devwil68
08-01-2011, 05:06 PM
wheels look great!
SSable
08-02-2011, 06:01 AM
Received the Ricks/VaporWorx tank today. WOW! exceptional craftsmanship.
https://static1.pt-content.com/images/pt/2011/08/80-1.jpg
CarlC
08-03-2011, 06:56 PM
It's kinda hard to see in the photo, but is there a screw in the threaded hole of the fuel module mounting ring in the leg that is mounted farthest forward?
SSable
08-03-2011, 07:22 PM
Yes. Small phillips head. Does it lock the ring?
CarlC
08-03-2011, 07:43 PM
Yes, that's the locking screw for the cam ring.
If you need to re-clock the module a bit to get the outlet pointed straight forward there should be some clearance between the module hat alignment tab and the mounting ring. Remove the screw, loosen the cam ring, re-clock the module, re-set the cam ring, re-install the screw.
I like the rear seats. I'm pondering that mod someday for mine to fit my two young boys.
SSable
08-03-2011, 08:04 PM
Will do! thanks for all your help and great work on the setup. To bad the tank has to go under the car! I just finished the last rear seat and taking them to the upholster Friday. Hood, Dash and Tank will be done this weekend.
SSable
08-05-2011, 07:38 PM
I recieved the RB hood hinges Thursday and installed today. Love these hinges, makes everything so smooth and quiet! No more bing-creek-bong-bing sounds anymore! I also installed the Ricks tank wired and plummed. Tomarrow Dash wiring!
https://static1.pt-content.com/images/pt/2011/08/81-1.jpg
https://static1.pt-content.com/images/pt/2011/08/82-1.jpg
https://static1.pt-content.com/images/pt/2011/08/83-1.jpg
https://static1.pt-content.com/images/pt/2011/08/84-1.jpg
CliffsBlueCamaro
08-10-2011, 12:15 PM
Great looking car! I'd like to ask you some ?'s about it - can you clean out your PM box?
Motown 454
08-10-2011, 03:58 PM
Beautiful build.
SSable
08-10-2011, 07:13 PM
Not a problem, all clean.
Justin
SSable
08-10-2011, 07:34 PM
Beautiful build.
Thanks Wayne, Been keeping tabs on yours as well. Very impressive and can't wait to see some more pictures.
icemanrd19
08-10-2011, 08:23 PM
how much did you end up paying for that tank? Any problems with fuel cut off?
SSable
08-10-2011, 08:56 PM
I would call Hector @ Ricks Tanks and he will give you a good deal. I have not driven the car yet, however in the next couple weeks it will be going to get dyno tuned. I don't expect any fuel issues.
Dobster
08-11-2011, 04:39 AM
I am ready to see the seamless windows installed...
Awsome build !
SSable
08-14-2011, 06:50 AM
Awsome build !
Thanks! I can't wait either!
SSable
08-14-2011, 07:04 AM
Update.
Lots and lots of wiring! still not done. Need to still wire the electric windows and door locks. HIDs and door handles will be in Monday. Received the rears seats Friday from the upholster and they came out great. They are comfortable and I feel they have the same leg room as the stock seat. I have about 4.5 inches to deal with on the package tray. The GTO tray will work for that with a little modification and recover.
https://static1.pt-content.com/images/pt/2011/08/95-1.jpg
https://static1.pt-content.com/images/pt/2011/08/96-1.jpg
SSable
08-17-2011, 10:14 AM
Pluggin away! new addition came today and they had to go on!
https://static1.pt-content.com/images/pt/2011/08/97-1.jpg
SSable
08-17-2011, 10:16 AM
Your turn to clean out PM's!
CliffsBlueCamaro
08-17-2011, 10:40 AM
LOL! Done!
Rols574
08-17-2011, 10:47 AM
those are nice. Who makes those?
SSable
08-17-2011, 10:59 AM
Ring Brothers made these.
Motown 454
08-17-2011, 07:07 PM
Nice handles they look good!
aps63
08-17-2011, 07:58 PM
The seats look amazing!!!!!!
Great job. Your passengers will love it back there.
SSable
08-18-2011, 03:29 PM
thanks guys!
SSable
08-19-2011, 07:23 AM
HID's installed. Man these things are bright! The slim ballast models take some time to startup. this is the kit I used.
http://www.carhidkits.com/xenon-hid-kit-99/digital-hid-kit-slim-ballasts-209.html
https://static1.pt-content.com/images/pt/2011/08/98-1.jpg
craigs73
08-19-2011, 09:50 AM
those seats out of a gto to? i was wanting to do something like that (buckets) for rear seats...... what are you going to use to fill in all those empty spaces around the seats? im wanting to make a custom center console to got between seats but havt figured out anything else
SSable
08-19-2011, 12:26 PM
Yes. modified them. I'm using a 1/4" cut pile from ACC for carpet and I just ordered extra. I plan to make panels that will fit in between and cover them. Just like how the 4th gens are. I'm also doing a custom console out of steel once I finish the headliner.
craigs73
08-19-2011, 07:21 PM
cant wait to see how you go about it
1968CamaroSS_Sam
08-19-2011, 11:40 PM
This car is turning out really nice. Great job. Love the door handles.
SSable
08-22-2011, 10:24 AM
Headliner! I suspect I will be on this for awhile.
https://static1.pt-content.com/images/pt/2011/08/99-1.jpg
SSable
08-23-2011, 06:14 AM
OverClock gets some media attention! LSXTV.com
http://www.lsxtv.com/features/car-reviews/swap-insanity-pro-touring-67-camaro-ls2-project-overclock/
https://static1.pt-content.com/images/pt/2011/08/capture-1.jpg
rfalker1
08-23-2011, 06:30 AM
wow your car looks amazing, i can't believe i have to see this... I kind of want those hinges too...!! Great Job though!!!
SSable
08-24-2011, 05:58 AM
Thanks Randal, I would consider RB hinges as they make a world of difference on hood function and looks.
SSable
09-04-2011, 08:31 PM
Took a week off and waited for the holiday to resume. Headliner is in and interior is about done. Waiting on door and kick panels. I'm happy how the seats fit and with added carpet around the rears worked great. IM going to start on the center console next week along with window installation. getting close! Im still thinking about the rear package tray idea with the speaker covers shown in the picture. More to come.
https://static1.pt-content.com/images/pt/2011/09/100-1.jpg
https://static1.pt-content.com/images/pt/2011/09/101-1.jpg
https://static1.pt-content.com/images/pt/2011/09/102-1.jpg
https://static1.pt-content.com/images/pt/2011/09/103-1.jpg
https://static1.pt-content.com/images/pt/2011/09/104-1.jpg
SSable
09-13-2011, 07:09 AM
New side windows are in. I have a little more adjustment left to get them lined up perfect. I love the speed of the Electric window motors, just need to careful as they might be able to do some damage if somethings gets in the way. Its been awhile since the last update because of all the prep work removing the chrome and powder-coating of all pieces. I went with a flat black to match the seals. I really enjoy the vent windows on the 67 but hate how it takes from the lines of the body, I feel this was the best way to make the vertical lines more discrete. I also tinted the windows outside of the car so nothing was missed and film lines are to the edge of the glass. It was also much easier to match the rear flush mount glass tint as well. Flush mount glass is next!
https://static1.pt-content.com/images/pt/2011/09/105-1.jpg
https://static1.pt-content.com/images/pt/2011/09/106-1.jpg
https://static1.pt-content.com/images/pt/2011/09/107-1.jpg
https://static1.pt-content.com/images/pt/2011/09/108-1.jpg
SSable
09-18-2011, 06:17 PM
Front flush-mount window installed! I also had the OEM wipers powder coated to match.
https://static1.pt-content.com/images/pt/2011/09/109-1.jpg
Motown 454
09-18-2011, 06:40 PM
Everything looks great. Nice job.
SSable
09-19-2011, 05:56 AM
Thanks Wayne!
amazing build, inspiration for mine that's just about to start! may I ask which rack and pinion supplier you used, and how you'd rate install? did you go power rack? I'm going to have to find a right hand drive set - I'm in New Zealand :)
SSable
09-20-2011, 06:25 AM
Thank you for your complements. Unisteer is the rack setup, not sure if they have right drive units, but I'm sure something can be adapted. Install is simple and strait forward, the challenge is finding headers and motor mounts that don't interfere with linkage. Any pictures of your EH Holden Wagon?
nicke
09-20-2011, 06:55 AM
Wow, nice work. That flush mount setup really compliments the black paint and smooth lines. Perfect. Just out of curiosity, what % tint are you running on the side glass? I really like it.
SSable
09-20-2011, 07:34 AM
Thanks Nicke! I went with a 30% UV. I could have gone with the smoke tint on the new glass but it not the UV blocking type. Need everything i can get to keep the heat down in an all black setup!
nicke
09-20-2011, 01:36 PM
Agreed. Good call. I think it looks perfect! Look forward to following this!
SSable
09-26-2011, 06:01 AM
Finalizing some issues with Hot starting. Interior is about done waiting on a few parts and start my center console. Vintage Air blows cold! I dove it for the fist time in over 8 years yesterday. Set up a 2 mile marker so I could set the speedo. Its got some power but needs some wideband tuning. LMR will be putting it on the dyno in 2 weeks to give me some time to workout some issues. It's about there! More pics of the rear flush mount windows coming.
https://static1.pt-content.com/images/pt/2011/09/110-1.jpg
MattWash08
09-26-2011, 06:36 AM
Nice! i love the look with almost no chrome on the car!!
nicke
09-26-2011, 06:51 AM
Wow, looks beautiful. Again, nice work!
1968CamaroSS_Sam
09-26-2011, 06:59 AM
Gorgeous car. Looking great.
SSable
09-26-2011, 10:02 AM
Thanks everyone. On the rack at LMR last week getting an extra O2 wideband sensor installed. I like this shot because the last time i took this angle was when i just finished putting in the rearend.
https://static1.pt-content.com/images/pt/2011/09/111-1.jpg
Motown 454
09-26-2011, 12:41 PM
Sweet!
FRENCHBLUE72
09-26-2011, 03:43 PM
Car turned out b!tchen..
StyleIn68
09-26-2011, 05:35 PM
Those door handles are AWESOME! Are they Camaro specific or universals you made work?
SSable
09-26-2011, 07:41 PM
Stylein68- you can get them from Ring Brothers, link is on the right. thanks all!
WICKED_SS
09-26-2011, 08:02 PM
That looks awesome! :jawdrop:
SSable
10-14-2011, 08:39 AM
It's been some time since my last update but things have been progressing. Some of the biggest happenings have been tweaking the front and rear suspension to get the ride height right and prepping for tuning and alignment. Here are some of the latest additions and changes.
I want to change the overall mount look of the rear bumper. I feel that it was afterthought back when the Camaro was designed to meet DOT approval. I decided to shorten the length and pull it in closer to the body. The final look will be powder coated flat black to match the tail panel.
https://static1.pt-content.com/images/pt/2011/10/112-1.jpg
https://static1.pt-content.com/images/pt/2011/10/113-1.jpg
I wanted more of cleaner look on the rear flush mount glass so I opted to fill in the gap with sealer.
https://static1.pt-content.com/images/pt/2011/10/114-1.jpg
Lastly, I used the Lokar e-brake setup with the stock foot brake. I was really please how easy it was to put in and how it adapted to the rear Baer brakes e-brake calipers. :cool:
https://static1.pt-content.com/images/pt/2011/10/115-1.jpg
More to come as I start on the custom door panels and center console!
Rybar
10-14-2011, 11:14 AM
Damn, this thing is coming out awesome. What kind of #'s did it put down on the dyno??
SSable
10-14-2011, 11:22 AM
Thx Rybar- I got a base tune on it a couple weeks ago but was unable to Wide-band tune it yet due to a hot-start issue. I should be ready to go for a second try in the next week. I will post the Dyno numbers.
SSable
10-24-2011, 06:58 AM
Little update. I have committed to the Houston Autorama show this Thanksgiving, so I'm going to finally finish this project this month. I have been enjoying some driving time with it to build some confidence and learn its behaviors. So far i have been very please with minor adjustments to the suspension. Still havn;t had the time to wideband on the dyno to get it's numbers, but it will happen soon. Interior is shaping up and started on the console. Picks coming.
https://static1.pt-content.com/images/pt/2011/10/driver-1.jpg
CruizinKev
10-24-2011, 08:41 AM
wow looks amazing!!! :twothumbs
T_Raven
10-24-2011, 10:19 AM
First time seeing this build. Very nice! I like the valve covers and coil mounts. It looks really good with the vent windows blacked out too.
sebtarta
10-25-2011, 02:43 AM
I was unmotivated to work in my car, after reading every post and analyzing every picture, you have managed to get me going again. Thank you! Your car is P-E-R-F-E-C-T!
Would you mind posting where and how you did the flush mount windows?
SSable
10-25-2011, 06:42 AM
Thanks all for your compliments. It's been a long road but take your time and do it the way you feel is right. No shortcuts! just take your time and think about it.
The flush mount setup is close to a basic window install. The pros can knock it out quickly, but I'm no pro. The key is to make sure you get enough seal down to lift the window up to the flush point. One trick I used was to make tall pucks of seal on the corners and middle of the glass and let dry, then use a razor blade to trim it down. Keep in mind that the window needs to flex a little to form right with the body, so place your pucks on the ends with only one in the middle. I mounted the window several times to get the height right. I even had to reapply some and wait till the next day to make sure it was right. Then when you apply the sealer go over the height of the puck by a 1/4" to make the seal, apply light pressure to set the height. The next challenge is to make sure align the window right as you have little room for adjustment once you place it in with sealer. During the last test fits I used painting tape with sharpie marks on the body and window to make sure it's aligned right. I had a buddy help with window suction cups to place it in. We did a couple practice runs before we applied the sealer to get motion right for correct placing. Use ample amounts of painting tape to avoid getting seal on the edges. Hope this helps!
SSable
11-11-2011, 08:01 AM
Well I have tinkered with making my own console or finding one that will work for some time. After looking online for pictures for ideas I found a suitable console out of the 79 Camaro with an auto trans that I liked. I ended up finding one locally on craigslist for $100 in great shape. I was able to make some adjustments quickly to the alignment, but it fits great on the trans tunnel and lines up with the dash panel with a little angle away from my right leg. I have since reinforced the inside with steel bar and welded it all up to the existing mounts supporting the shifter and arm rest. I cut holes for window/lock switches and a mount for the Informant system. I picked up some leather covered aluminum panels for the doors and rears and installed the Modo Innovations pedals. I will have some more pictures of the console once it's back from the upholster. Im also waiting the on door handles from Fesler. Time is ticking on the show!
https://static1.pt-content.com/images/pt/2011/11/116-1.jpg
https://static1.pt-content.com/images/pt/2011/11/117-1.jpg
https://static1.pt-content.com/images/pt/2011/11/118-1.jpg
ryeguy2006a
11-11-2011, 12:39 PM
I love the petals, where did you get those from?
SSable
11-11-2011, 12:51 PM
Modo Innovations
nicke
11-14-2011, 11:43 AM
Awesome, its really coming together nicely! Can wait to see more pics of the body and the ride height you decided on!
Blevinator
11-14-2011, 12:46 PM
Hello
Looking at a similar rear setup in my 68
Can you tell me the rim size, width, and backspace, as I want 345's as well!
Thanks again!
SSable
11-14-2011, 01:30 PM
Rears: 19x12, 5.25 BS, 345/30/19 Pilot Sport
Front: 18x8.5, 5.25 BS, 255/40/18
I would also trim your fender lip for more clearance.
Blevinator
11-14-2011, 05:54 PM
Thank you!!!
I rolled the fenders, notched the frame.
I am looking at using Corvette wheels, so widening rear end.
Using Speedtechs torque arm setup.
Is your rear end factory width?
Thanks again!!!
SSable
11-14-2011, 08:33 PM
Thank you!!!
Thanks again!!!
No sir 55" flange to flange. I have forgoten the stock size, maybe someone can chime in.
SSable
11-14-2011, 08:35 PM
63" maybe?
SSable
11-17-2011, 12:04 PM
Launching social media effort to drum up support for Autorama in Houston. Please take a look and "like" it!
Overclock's Facebook Page (https://www.facebook.com/pages/Project-OverClock/284104114935989)
Whopper
11-27-2011, 07:33 PM
I saw Overclock at the Autorama yesterday. I was so impressed I had to google it which led me here. If you think it looks good in pics, see it in person. Well planned, well executed...just stunning. Truly my favorite of the show. I thought it would be from a 'name shop' so being able to see the progress of a normal guy build made me join just to give SSable some kudos. Now I'll be up all night looking through the rest of the forum.
rickpaw
11-28-2011, 08:12 AM
Saw the car at Autorama over the weekend. Very nice.
SSable
11-28-2011, 08:51 AM
Thank you Whopper and rickpaw!
I was a very successful campaign and saw some great cars. Project Overclock took 2nd Place Outstanding in Mild Hardtop. I believe there were about 15 cars in the class. It lost to a Paint House/Sponsor show car. It was a great experience and outcome for a first showing. I plan to make some mild adjustments and additions and enter the Chevy Expo next year. More pictres of the finished interior coming soon!
https://static1.pt-content.com/images/pt/2011/11/autorama-1.jpg
https://static1.pt-content.com/images/pt/2011/11/autorama1-1.jpg
https://static1.pt-content.com/images/pt/2011/11/autorama2-1.jpg
SSable
12-07-2011, 11:45 AM
Well I have finally got some quality pictures taken of the car and wanted to share. I would like to have some more professional shots done once I finalize some things. No Dyno tune yet, but it's coming! These pictures were taken at the Coffee and Cars Event on Dec 3rd, last weekend. Great turn out and will be attending again.
https://static1.pt-content.com/images/pt/2011/12/1-1.jpg
https://static1.pt-content.com/images/pt/2011/12/2-1.jpg
https://static1.pt-content.com/images/pt/2011/12/3-1.jpg
https://static1.pt-content.com/images/pt/2011/12/4-1.jpg
https://static1.pt-content.com/images/pt/2011/12/5-1.jpg
https://static1.pt-content.com/images/pt/2011/12/6-1.jpg
Steve68
12-07-2011, 03:08 PM
looks great!!! car shows very nicely!!!!
SSable
12-07-2011, 06:52 PM
Thanks Steve! Its very fun to drive as well.
icemanrd19
12-07-2011, 07:04 PM
where are you located in tx? where did you get the engine and how much? What are the specs of the wheels you are running? I noticed you mentioned cars and coffee. Hopefully you are close to the dallas area that i can come check out your ride
SSable
12-07-2011, 08:16 PM
Im in the houston area, check out eairlier in the build for specs of everything. I rebuilt the motor myself you can get just about any LS based motor on ebay or locally. Price varies.
nicke
02-15-2012, 10:42 AM
Really nice job on the car. Simply beautiful.
72Z/28
02-15-2012, 01:36 PM
One word to describe this build: BEAUTIFUL
I wonder what sealer you used to fill in the rear window gap?Do you have a closer shot of the rear window showing the gap filled with the sealer?
SSable
02-15-2012, 04:36 PM
72z28 - I used 3m weather seal with lots of time and tape. I will try to find a closer picture for you. The you for the complements!
SSable
02-15-2012, 04:49 PM
I finally updated my door sill plates with the Anvil CF units. Fit is correct and as stock. Still need to have it wide-band and get some numbers.
55600
SSable
02-15-2012, 05:01 PM
I entered Overclock in the Corvette and Chevy Expo in Houston over the weekend and took home best in class Pro-Touring. Seven cars where in my class and 5 of them were 69's. Who says 69's are more popular? haha
55601
WICKED_SS
02-15-2012, 07:00 PM
Congrats! car looks great, mark one up for us 67 camaro guys!!! :headbang:
rickpaw
02-16-2012, 10:37 AM
Congrats on the award. I may have to look at those Anvil CF sill plate for my car. They look sweet.
Are you planning on taking the car on powertour this year?
SSable
02-16-2012, 12:47 PM
Thanks! No powertour this year, I'm thinking maybe next.
Motown 454
02-16-2012, 01:47 PM
Congratulation's Beautiufl car.
LS7 Z/28
02-16-2012, 03:11 PM
Could you tell me what company you got the flushmount glass from? I tried to look further back in the build threads, but didn't see it. Project looks great.
sokoloka
02-16-2012, 04:38 PM
When you powdercoated things like the wipers and trim black, did you strip the chrome first?
1968CamaroSS_Sam
02-16-2012, 04:42 PM
Great job on the car. That is so gorgeous.
68vert
02-16-2012, 05:42 PM
Beautiful car!
SSable
02-17-2012, 06:23 AM
Classic industries has them. Sign up for their email newsletter and wait for them to have a 15-20% off sale. They are not excluded from discounting. ;-)
SSable
02-17-2012, 06:33 AM
Majority of the trim pieces are stainless, so you can ruff them up with sandpaper and shot. Parts of the 67 vent window are chrome and will need to be de-chromed, which any chrome shop can do. Make sure you find a quality powdercoater as it take skill to put just enough down to prohibit any chipping and texturing.
DirtShark
02-17-2012, 09:04 AM
Very well thought out and executed build...Congrats!!!
joeelutz
02-19-2012, 07:17 PM
Beautiful car and very tastefully done. I appreciate you sharing among other things, the wheel/tire size, backspace and axle width. I have two more questions about that since a 345 has to be a tight fit even with trimmed lips and mini tubs. 1. How much clearance do you have between the inner sidewall and the tub? 2. Does the rear tires ever rub say when you roll the suspension going through a dip or turning into a steep driveway?
Thanks again and congrats on a great build!
SSable
02-20-2012, 08:24 AM
Thank you sir, If i remember right i have 1.5-.75 clearance from the inner well. Yes, you will impact your inner well on a hard roll on a steep driveway if your height is not set correctly. It all depends on your suspension setup. I would suggest looking at airbags if you have varying weight and/or lower stance preference with running such a large tire.
E.rodz
02-20-2012, 05:57 PM
very nicely done. love the attention to detail.also checked out your article on lsxtv. keep up the great work.
SSable
04-18-2012, 06:01 AM
Yo all, been awhile since any updates. Overclock has been to many car shows locally around Houston and has done very well. People love Pro-touring cars so if you have a completed car get out and show it! you will have a blast!
Check out the HUD installed on the console! Yes it's wireless via bluetooth.
http://www.facebook.com/v/10150713830512622
cardude23
04-18-2012, 06:31 PM
ive been following your build for a while and seen your car at the rosenburg spring fling i wanna say you have a piece of artwork. and the attention to detail is amazing. i never could catch you around the car over the weekend but just wanted to stop here and tell you. and wanted to say your car is a inspiration to get mine were i want it.
overZealous1
04-18-2012, 06:58 PM
awesome build man. good attention to detail!
SSable
04-18-2012, 08:44 PM
Cardude23, if you happen to be on the northside at Niffty50ees on Saturdays come by and talk. Thank you both for the compliments!
SSable
06-12-2012, 03:43 PM
With over 1K on the odometer she is a blast to drive on the weekends. But she still needs some beauty time and like every girl, pampered and shown off!
I was invited to the Classy Chassis Concourse elegance in Houston and was placed next to an amazing work of art the 2012 Ridler Award winner. He took the Chairmans award of excellence and I was given 1st place Resto-mod/Street Machine.
60686
Ron.in.SoCal
06-12-2012, 04:13 PM
Congrats SSableman. You deserve it! :Cheers:
kengi1600
06-12-2012, 05:33 PM
Sweet
diesel25lrs
06-12-2012, 06:54 PM
Very nice build! Hope mine turns out that nice!
AUTODYNAMICS
06-12-2012, 08:41 PM
I like the girl on the calendar .......hot
SSable
08-06-2012, 08:18 PM
https://www.facebook.com/OverclockCamaro
WICKED_SS
08-07-2012, 06:31 PM
WOW that video is just plan sick! love it!
Jon69RagTop
08-19-2012, 07:57 AM
What a great build, nicely done.
Richio1
08-19-2012, 04:39 PM
Awesome video. What a great idea!
66larkgs
08-20-2012, 06:37 AM
GREAT Video!!!! Those guys did a great job..
SSable
02-01-2013, 08:48 AM
Just want to add an additional video that includes a summary of the build and build pictures.
http://youtu.be/M9g1bXjC-h0
salvadorspisso
06-12-2013, 08:44 AM
i've notice that your rearend it's 55" wide, i want to know what its the backspace of you rear wheels
Rols574
06-12-2013, 10:43 AM
silly question, that gas cap where did you get it?
moose knuckle
06-13-2013, 01:29 AM
From page 9
SSable
06-13-2013, 07:33 AM
Ridetech Coachworks.
SSable
06-13-2013, 07:34 AM
From page 9
Thanks Moose.
jhuey71
07-16-2013, 08:25 AM
Your car looks amazing. I recently purchased an interior out of a 05 GTO for my 68 Camaro. How did you mount the front seats? Did you fab new brackets/frames? Thanks
Jason
SSable
07-18-2013, 06:27 PM
79462
79463
79464
79465
79466
TonyHuntimer
07-18-2013, 10:13 PM
Nice job! Well done!
Tony Huntimer
RaceHome.com
19736.o
07-18-2013, 10:16 PM
Very nice
