View Full Version : Powder Coat Question
paulk68
08-02-2008, 06:48 AM
i am going to have my chris alston camaro front clip powder coated. the guy that is doing it said that he can plug all the holes but doing that leaves a little build up around each plug. he suggested just retaping the holes after. what do you guys think is best.
thanks
oestek
08-02-2008, 07:03 AM
I'd leave the holes open and re-tap them later. It's a little bit of a hassle, but it comes out nice and clean.
jerome
08-02-2008, 07:44 AM
on the other hand, he should try to keep sand out of the threads, cause you will break taps and want to kill him if there is sand stuck in the threads.
quadfather
08-02-2008, 10:36 AM
on the other hand, he should try to keep sand out of the threads, cause you will break taps and want to kill him if there is sand stuck in the threads.he's right when they sandblast the hole it makes a mess . i used short set screws in the holes to plug them just below the surface.
paulk68
08-06-2008, 02:45 AM
good to know so would you say i should put in the set screws for the sand blasting and then remove them for the powder coating? thanks again Paul
Fireeater
08-14-2008, 02:46 PM
Paul,
Did you get the frame done yet?
Dave
paulk68
08-14-2008, 03:33 PM
not yet, been way to busy at work. looking to do it by the end of the month.
