View Full Version : Bandsaw Blad MFG???
PhillipM
07-30-2008, 03:32 PM
Which bandsaw blade brands are you favorite?????
I have tried the Lenox blades and weren't very happy with the quality of the weld or the blade. Especially for the 30 or so dollars they were a piece.
What are some other brands??
astroracer
07-31-2008, 08:58 AM
I use Morse blades purchased through Enco.
Follow the link...
http://www.use-enco.com/CGI/INSRHI?PMSECT=0000000689
The last time I bought blades 2 yrs ago they were on sale for 5 or 6 bucks apiece. I stocked up big time and have only changed blades once since then...
Mark
PhillipM
08-01-2008, 08:47 AM
Thanks!
cdoggy81
08-08-2008, 08:02 PM
Try Morse or Simonds. Also, Fastenal will make you one from coil stock to any size.
Jim Nilsen
08-23-2008, 02:45 AM
DoAll also makes some really good blades. They have a multitooth blade that will save a bunch of time and extra blades to do the jobs that are different in thickness without changing blades.
You can get DoAll blades thru Grainger.
Otto-813
11-05-2008, 02:34 PM
Morse also, found them on ebay for a good price.
droptop73
06-02-2010, 05:38 PM
Check Production Tool, they have several outlets. Get a couple bi-metal blades with 18-24 teeth for thin material and 10-12 teeth for thicker material. If you cut wood or aluminum use a 6-8 tooth (1/4" or thicker)
