View Full Version : 67 Camaro ,Biggest wheel size 18" HELP!!!
huggero
07-28-2008, 07:29 AM
Ok im very confused, Ive heard 10 diff things from 20 diff people. I have a 67 camaro with a moser 12 bolt and a hotchkis TVS rear suspension, QA1 shocks mounted in the stock location. My lip is not rolled because the car is painted. I want to run a 18X9 Budnik wheel in the rear. What is the biggest tire I can run in the back and not create any rubbing and still clear the wheel well? I am also using A wilwood rear disk brake kit. Any suggestions would be greatly appreciated. Thank you.
class67
07-28-2008, 09:07 AM
If all that you are looking for is tire size, you can safely run a 275/40/18 with a 9" rim provided you have the proper backspacing (5.25 or 5.5).
huggero
07-28-2008, 11:12 AM
So it would be safe to assume that the 5.25 backspace would be the safer route so it doesnt rub? And also I see alot of people running 17" wheels instead of 18". Will the 18 " wheels not clear the wheel well as good as the 17" Im just curios. Im going to spend alot of money on the Budniks and I want to get it right. Thanks
Nine Ball
07-28-2008, 11:22 AM
18" will give you more clearance around the lower shock mounts, as well as more clearance around brake calipers/rotors.
275 wide tires shouldn't rub.
