NOPANTS-68
07-27-2008, 04:06 PM
I'm running a 468 and am having some issues with running fat at idle and slow cruising speeds. The specs are:
ported 990 rect port heads
Comp solid roller - 262 @ .50- .652 lift and a 110 center
10.8 :1 comp.
RPM Air-gap intake
Holley 950 HP carb.
all upper-end supporting parts- Eagle bottom end, fully studded, Holley HP150 electric pump- Aeromotive reg set a 6.5 PSI, etc.- Tremec TKO600 trans.
It's very radical but idles pretty happily at 1100 RPM. I'm running 74s in front with 80s out back, have a 45 power valve in it, mixture screws dialed to make max vac @ 9-10 inches, floats are perfect. The driveability is excellent and it rips pretty hard on the big end. However, at idle it's very fat to the point where I can actually see the vapors coming from the pipes after a short time sitting still. The longer it idles the worse it gets and the tach begins to fall to 900 RPM where it stabilizes and runs pig rich. The regulator is pretty stable at 6 PSI so I don't think it's blowing past the needle and seat. Am I way off or do I have another issue? TIA, Dave
10.8 :1 comp.
RPM Air-gap intake
Holley 950 HP carb.
