View Full Version : *lt1 guys* opti question
lt1chevelle
07-26-2008, 07:05 PM
i took the opti vent line off that runs to the intake and hooked somthing else up there and never hooked it back up. when i was out driving the car today it backfired and poped and shut off. once i hooked the tube back to the intake vacum line it seemed to run fine? could that be the problem?
paul67
07-27-2008, 07:24 AM
What yr is the opti ?
Samckitt
07-27-2008, 08:42 AM
That vent line removes some kind of little particles in the air that result from a spark between the rotor & the terminal where the plug wires connect. I guess if that doesn't happen it can misfire.
lt1chevelle
07-27-2008, 11:38 AM
its a 95. the car was missfiring but once i hooked it back up seemed to run fine. ill have to drive the car around the block and see if i got it fixed. its find scary tho it almost died in the middle of a intersection.
