View Full Version : Pic of camaro with GW cat 5 leafs
Anyone have one? I would like to see the stance. I want to go with these but i'm afraid the 1 1/4 drop won't be enough for the right look. If it's not is there any way of dropping the car another 1/2 inch out back? Blocks?
zbugger
07-27-2008, 09:11 AM
What car?
Spiffav8
07-27-2008, 07:24 PM
I used the L2CAT5 on my Camaro. I think that's what your talking about. Very happy with the way they lowered the car.
Thank you... Perfect! I was looking for a 67 pic.
What size tires are out back?
4MuscleMachines
07-28-2008, 10:45 AM
Somehow mine looks lowered even more with the same GW leafs. This pic was taken a few weeks after the install and letting the car sit.
https://static1.pt-content.com/images/pt/2008/07/2s0z487-1.jpg
Spiffav8
07-28-2008, 11:16 AM
The 69 looks lower because the the shape of the rear wheel well. I think that is the perfect look for a 69.
Damn True
07-28-2008, 11:21 AM
Concur. The rounded upper portion of the 67/8 wheelwell opening makes them look a bit less low than a 69. The stronger lateral lines on the 69 also contribute to making them look lower to the ground and less "tall" as well.
Spiffav8
07-28-2008, 11:22 AM
I have the Nitto Extreme ZR 285/35 mounted on iForged Astra 18x10s. Nineball can hook you up with a set if your interested.
billybobdupree
07-29-2008, 01:35 AM
WOW! love the wheels.
Who is the manufacturer of those wheels? What size tire (front/rear)are you using?
Billy
TitoJones
07-29-2008, 09:11 AM
Those wheels look like they are from Kenesis.
More than likely an 18" diameter all the way around.
Tyler
