View Full Version : Circuit breakers that take place of spade fuses.
Samckitt
07-22-2008, 10:33 AM
Just found this & thought I would share, I haven't used them, so I can'
t comment on them. But they take the place of a normal spade type plastic fuse:
http://www.wiringproducts.com/index1.html
funbnme
07-22-2008, 11:27 AM
Do they automatically reset or do you have to flick a little switch on them to get them to reset?
If they automatically reset, I wouldn't use them in place of a regular fuse. Then circuit would keep coming back to life and the short (or whatever caused the blowout) would keep tripping it. Don't know if that would cause damage to any of the components.
I did use a resetable breaker like that at my engine cutoff switch where I had a keep alive jumper for the computer. It was helpful when I'd try to start the car, but forgot to flip the switch. It would trip so the car couldn't start, but I didn't have to get back into the trunk to change a fuse everytime I forgot.
Samckitt
07-22-2008, 11:30 AM
Type 1 auto reset circuit breakers will cycle the circuit breaker until the overload condition is removed. Circuit breaker housing is grey plastic with gold cover. Amperage and voltage ratings are stamped on the cover. Meets SAE J553 specifications for type 1 circuit breakers. Compatible with ATC fuse blocks. Available in 10 amp, 15 amp, 20 amp, 25 amp, and 30 amp capacities.
Type 2 modified reset circuit breakers will keep the circuit breaker open until the overload condition is removed. Circuit breaker housing is grey plastic with silver cover. Amperage and voltage ratings are stamped on the cover. Meets SAE J553 specifications for type 2 circuit breakers. Compatible with ATC fuse blocks. Available in 10 amp, 15 amp, 20 amp, 25 amp, and 30 amp capacities.
Type 3 manual reset thermal non-cycling circuit breakers will remain tripped until the operator resets them by pushing a button located on the breaker. Circuit breaker housing is grey plastic with silver cover. Amperage and voltage ratings are stamped on the cover. Meets SAE J553 specifications for type 3 circuit breakers. Compatible with ATC fuse blocks. Available in 10 amp, 15 amp, 20 amp, 25 amp, and 30 amp capacities.
