View Full Version : Lowering a 72 Grand Prix
maleezer
02-15-2005, 10:39 AM
I there anything out there to lower my grand prix i have been looking and i cant find anything...I know it is a gbody if that helps with anything....
dennis68
02-15-2005, 11:15 AM
A 72 Grand prix is a "G" body???
How about cutting the coils?
maleezer
02-15-2005, 10:25 PM
Yea but i really didnt want to do that..But if i have no choice i guess i will have to
Roadrage David
02-16-2005, 01:05 AM
try PSC Performance Suspention Componends
maleezer
02-16-2005, 04:38 PM
what is there web address if u know :worship:
Roger Poirier
02-17-2005, 06:51 PM
try www.performancesuspension.com
TPI Monte SS
02-17-2005, 07:23 PM
A '72 Grand Prix is an A-body, so Chevelle lowering springs will work.
Motornoggin
02-17-2005, 08:57 PM
Yup, 72' GP is a "stretch A" body, so any suspension parts for 68-72 "A" body GM cars will work. Keep in mind that the factory springs for the GP are already lowered about 1 1/2" and are higher rate as well.
Roger Poirier
02-19-2005, 06:54 AM
ames performance has a catalog just for grand prix items.
www.amesperf.com
02-19-2005, 07:57 AM
Ok lets try to keep in mind that it was a long time ago and I was very young...so go easy, please? :nopity: If you ask about this in person, I will deny everything...
A friend and I built a Grand prix low rider with hydraulics. With a big hydro car you want to try to have as much spring as possible.We reinforced the frame and we added cups to the upper frame and lower arm to house the spring and ram.It was mounted in a hole in the upper cup. It might apply to your car. A 1" cup will lower the car 2". Ours were made of 1/4" steel but you maybe able to use 3/16".
ProTouring442
02-20-2005, 03:36 AM
The 72 Grand Prix is a G body... but it's really just a stretched A body. Confused? The first G bodies were really just A body 4 door frames with the body pushed back on the frame and the difference made up in longer front sheet metal. They also used a notch back roof. The Olds Cutlass Supreme body is a G body body on an A body frame (just to make it a little more confusing). In the end however, none of this matters for the suspension. It's still an A body frame.
Just as an aside, the 80's G bodies were called G bodies because of their notch back roof as well. The 80's Malibu and it's Pontiac sister were really called A bodies, but for the sake of the suspension, they shared the same frames with their G body counterparts.
maleezer
03-01-2005, 06:58 PM
Thanks guys u have been a huge help thanks for that ames web site.:3gears:
