View Full Version : 18x12/18x9 wheels under $2000?
Abbott
07-21-2008, 04:59 PM
Whats up guys, having a hard time picking a set of wheels, or rather finding a set within my budget. I am looking for 18x12 rear and 18x9 front for under $2000 but this seems to be a difficult task.
Does anyone have any ideas/recomendations? I love the Livewires from Rushforth, but they are a bit out of my price range, as are most the others i have found. Thanks for any ideas guys! :cheers:
Taylor1969
07-21-2008, 05:10 PM
intro classics... i paid $1500 for my 18X9.5's.... 18X11's shouldn't be that much more.
https://static1.pt-content.com/images/pt/2008/07/DSC00003-1.jpg
skatinjay27
07-21-2008, 05:28 PM
you might be able to get some ccws for 2k...
it the 18" and the 12" needs are whats hurting your budget...
The WidowMaker
07-21-2008, 08:15 PM
anything over 10's are going to be expensive. most need a 3 piece for this, and theres no way youre going to come in under 2k for those.
Boesch
07-21-2008, 09:05 PM
What's been said above is exactly true. Going to anything over 10" wide is going to add quite a bit of cost. If there are any Intro styles you like just let me know. I can get you a set of 18's with your budget but it would be in 10" width instead of 12".
Abbott
07-21-2008, 09:25 PM
Ah bummer, but i figured as much. I guess ill just have to roll my stock 15s with my drop and mini tubs for a while so i can save up :headbang: Thanks for your input guys!
-Abbott
1969CamaroRS
07-22-2008, 03:56 AM
Check out Weldcraft Wheel Widening (http://www.weldcraftwheels.com/Wide.htm). They can widen your existing rims, or perhaps take a new cheap pair of narrow wheels and make them 12" wide.
Something else to consider.
hotrdblder
07-22-2008, 04:27 AM
ccw's will run you 2600 new, figure out your backspacing and keep a look out for used wheels, they pop up fairly often
DriverzInc
07-22-2008, 12:36 PM
Or you could always run an 18x10 with 305's and still look good??
Finch
07-22-2008, 02:47 PM
I went with the Z06 replica wheels.
18X9.5 in the front and 18X12 in the rear for just under $900 to my door. Only thing I had to do was run 1" adaptors in the front.
The WidowMaker
07-22-2008, 07:40 PM
jon - any word on the new wider hoops for the 2 piece wheels?
Jimmy Sean
07-23-2008, 05:08 AM
Check out my build thread and see what I did to get 18x12 wheels. May be something to consider, I have $1100 total for all wheels in mine.
Abbott
07-23-2008, 02:59 PM
Thanks guys, these are all great ideas and things to think about. Im sure ill figure something out, or just eat roman noodles for a few months and pick up a set of Rushforths :yum: Thanks again all, ill let ya know which direction i go!
-Abbott
