View Full Version : 315/35/17's on anova
craigs73
07-20-2008, 10:04 PM
i currently have a 73 nova and am putting a rear tub kit in .i was wondering if anyone has pics of them on a nova would be nice but mainly want to see how wide the 315's are :woot:
WILWAXU
07-20-2008, 10:53 PM
I'm interested also. Which tub kit are you looking at?
craigs73
07-21-2008, 08:59 AM
the deep tub set from detroit speed you get everything you need to tub it for 1320 dollars you can get a 17 inch rim 11 inch wide with a 315mm tire under there but you have to cut down the the rear axels.if you dont you still can get 295 mm tires. very nice setup for the money
07-21-2008, 10:29 AM
heres one of my projects...
backside...http://hometown.aol.com/gumbydmit22/images/72rearmock003.jpg
craigs73
07-21-2008, 07:16 PM
is that with the 315's if so could you show a pic from behind the car very nice project man i can't wait to get started on mine did you pull the rear lip out to get a wide tire under there or is that a rust repair :cheers:
craigs73
07-21-2008, 07:18 PM
wait a minute i just found the pic from behind :hand:
07-21-2008, 08:24 PM
nope that was rust repair...gotta love it.
craigs73
07-21-2008, 08:30 PM
so those are 315's. i seen the pic's on your site man you do pretty good work i only wish i could do that for a living. is those leaf springs in stock location in those pic's. and one more question for now lol! is that car siting at stock heigh because i am getting the kit from detroit speed that has the tups and leaf springs that are moved in and was going to get the kit that lowers the car 3 inches.
craigs73
07-22-2008, 09:53 AM
what is the measurments on the rear end how many inches is the rear end from end to end and what is the backspace on your wheels
07-22-2008, 07:47 PM
craig,
I don't have my notes with me but I recall 55 1/2" with rotor thickness and the rim back space is 5.5". I have 1" inner clearance and 5/8" outer. I can drop it all the way down with no rubbing.
Im using a stock tank and Landrum leaf springs which are not as wide as a stock ones.
craigs73
07-22-2008, 08:02 PM
thanks and once again sorry for all the questions but your car you are building is what route i planed on going so you already have done what i am about read to do so how exactly would i measure to see what the rearend length would be and the backspacing would be i figured that the rim backspacing would be 5.5 :poke: :help!:
07-22-2008, 08:34 PM
cool, if you need any help just ask.
Honestly, Buy the rims and tires, make a hole for them to fill, then set up your rear end to fit. Much cheaper to do this way on some projects.
WILWAXU
07-22-2008, 08:56 PM
craig,
Im using a stock tank and Landrum leaf springs which are not as wide as a stock ones.Do you think a 335 is possible with a mini-tub?
craigs73
07-22-2008, 09:45 PM
yeah i just ordered the mini tub kit from detroit speed they say a 17x11 inch wheel will fit with a 315 tire. so when i get the mini tubs in then order the wheels? i figured i would buy those 17x11 with 5.5 backspacing.
07-23-2008, 06:32 PM
Do you think a 335 is possible with a mini-tub? On 17's? yes ...on 18's yes, but with a bit more frame work and link suspension. No way with leafs.well....I wouldn't say no way but you get what im saying.
WILWAXU
07-23-2008, 07:08 PM
On 17's? yes ...on 18's yes, but with a bit more frame work and link suspension. No way with leafs.well....I wouldn't say no way but you get what im saying.Yeah, I'm thinking a Quadra Link or G-bar setup.
craigs73
07-23-2008, 07:14 PM
yeah thats why i went with 17's instead of the 18's
craigs73
07-25-2008, 05:31 AM
when i shorten my rearend i don't need them for any thing do i?:fingersx:
huffhinesce
07-25-2008, 06:31 AM
Mr. Quick. What all did you do as far as your suspension on the 69? I love the stance and would like to make my 74 to sit similar. I also like your wheel choice. That's about the same size wheel and tire that I want to use.
07-25-2008, 06:31 PM
when i shorten my rearend i don't need them for any thing do i? I don't follow, how copy
Mr. Quick. What all did you do as far as your suspension on the 69? I love the stance and would like to make my 74 to sit similar. I also like your wheel choice. That's about the same size wheel and tire that I want to use. Thanks, ATS front tall spindles, Eibach front springs cut to size, rear 2" drop multileafs. The front rims were narrowed to 8" wide the rears are stock 9".
old add: http://www.chevynovatrader.com/details.php?id=6667
craigs73
07-25-2008, 07:11 PM
sorry i was trying to say that when i shorten my rearend do i need to keep the axles out of them for anything. on your ragtop nova what is your front wheel size and backspacing and tire size you are going with and what have you done to the front suspension.drop spindles cut loops out of spring and etc.
07-25-2008, 07:25 PM
oh ok. Now when you do your rearend you need to buy new axles. Just check with the shop that is going to do the work. where are you?
Front is a 275 on a 17x9.5 6" backspace rim. I doubt you will get the same results since my frame,fenders and wells have been modified to fit it all. On a stock frame 245 45 17's on a 17x8 4 3/4" -5" backspace rim should do better. You will have to measure your car to be sure.
craigs73
07-25-2008, 07:48 PM
i live in ohio about 45 minutes from columbus.Mr quick did you get the pm i sent ya
07-25-2008, 10:20 PM
sorry, yes I did. Excellent price. Git er done
craigs73
07-26-2008, 06:22 PM
alright then i justed wanted to make sure that 5.5 backspacing was right before ordering them once i order them i am stuck with them but will order them monday then will take 8 weeks to have them made so mr quick you want to sell me yours just joking
craigs73
07-31-2008, 08:14 PM
well i got a even better deal on the same wheels from a store on ebay called https://static1.pt-content.com/images/pt/2006/01/s-1.giffastestlane (http://myworld.ebay.com/ebaymotors/fastestlane/) i got 2 17x8's with 4 3/4 backspacing and 2 17x11's with 5.5 backspacing all four caps, chrome valve stem, and all the lug nuts for $1020 and no shiping fees:lol: this guys has very fast shipping as well i ordered them and got them 2 days later. the backs have to be made and he gave me a 3 week time frame. which jegs gave me a 8 week frame:wedgie:
austindub
07-31-2008, 08:37 PM
https://static1.pt-content.com/images/pt/2008/08/1449818323_293e67d38a_b-1.jpg
07-31-2008, 08:46 PM
well i got a even better deal on the same wheels from a store on ebay called https://static1.pt-content.com/images/pt/2006/01/s-1.giffastestlane (http://myworld.ebay.com/ebaymotors/fastestlane/) i got 2 17x8's with 4 3/4 backspacing and 2 17x11's with 5.5 backspacing all four caps, chrome valve stem, and all the lug nuts for $1020 and no shiping fees:lol: this guys has very fast shipping as well i ordered them and got them 2 days later. the backs have to be made and he gave me a 3 week time frame. which jegs gave me a 8 week frame:wedgie: any extra charge for doing the 11's??
craigs73
07-31-2008, 09:07 PM
the only thing he charged me was $1020 you make anymore progress on your 72 . man that car is nice who's car is that man
craigs73
08-04-2008, 07:15 PM
got the rears today:seizure: Way early:twothumbs a few weeks early and they are perfect i highly reccomend the guys i bought them from :twothumbs
huffhinesce
08-06-2008, 07:31 AM
I appreciate the info Mr. Quick. I'm working on the floor pans on mine now but will soon be on to the quarters, tubs, and rear suspension plans. Very helpful pics on your site. I'm thinking of trying to make my own tubs though, just splitting the stock one and adding a strip down the middle. This would make it a lot cheaper.
WILWAXU
08-31-2008, 12:19 PM
craig,
Im using a stock tank and Landrum leaf springs which are not as wide as a stock ones.Digging up some old info.
What's the specs (part number) on the Landrum springs you used?
What was need to make them work on the Nova?
Thinking seriously about going this direction.
Thanks!
