View Full Version : starter tech
Slow Ride
07-17-2008, 06:08 PM
My nice gear reduction starter gave up. It started making grinding noises and would slip sometimes. Then it quit, so I took it apart and found the problem. The housing for the clutch is cracked so I need to replace it. How do I get the snap ring off the end of the shaft so I can get the gear and clutch off?
Slow Ride
07-17-2008, 07:19 PM
Thanks Dan
This is the starter.
http://www.db-starter-alternator.com/Items/6449-suburban?&caSKU=6449-suburban&caTitle=CHEVY%20SUBURBAN%20NEW%20STARTER%2094%2095 %2096%2097%2098%2099%2001%20%20%206449
It has worked great for me. The only reason it broke was my timing light went to hell and I had 55 degrees of locked out timing. There must be a simple way of getting the gear and bendix off the shaft.
