View Full Version : RS conversion help
gmjj13
07-16-2008, 06:24 PM
i bought a complete RS headlight conversion kit for my 69 camaro. i bought the DSE electric doors as well. originally my car was a standard 69, but i always wanted the RS headlights. i also put RS fenders on the car as well. my problem is i am not 100% sure on how it all goes together. does anyone know where i can find a diagram or have some :pics2: that would help me in the installation of this set up? any and all help would be greatly appreciated. thanks.
mikey
07-16-2008, 09:07 PM
I'll try to get you some pics this weekend when my wife gets back from Toronto with the camera.
Motown 454
07-17-2008, 09:43 PM
Jeff I had some directions I'm tryiong to look for if I find them I send them to you .
gmjj13
07-18-2008, 04:56 AM
thanks for the help.
gmjj13
07-19-2008, 10:23 AM
TTT anybody else? i'm ready to put the front end together, just need some good info.
jag4902
02-06-2009, 09:20 AM
Jeff,
Looking to do the same. Did you get any help.
19sixtynine
01-07-2010, 11:50 AM
I'm about to convert my 69 as well and am wondering what exactly I need to buy? I'm trying to do this on a budget but with parts like the DSE electric doors for convenience. I do believe the car was an original RS because of things such as reverse lights in the lower rear valance, vacuum hoses coming out of the wiper motor and I believe one of the fenders does have the tab towards the front.
My question is what in total do I need? and why?
Any help is GREATLY appreciated..and suggestions on how I might go about doing this on a relatively tight budget.
Thanks all!
Gregster
01-08-2010, 07:50 PM
I just did this but am not finished and did it on a budget. I was able to locate good GM used Rt. & Lf. capsules for $300.00 including chrome grilles. But if you buy 2 new ones it will run about $350.00 for repros and you will need 2 chrome grilles for $120.pr., a RS grille about $170.00, RS fender adapter brackets unless you have RS fenders currently $25.00 to attach the capsules, the back of the capsules attach where your current housings do on the radiator support. I do not currently have the DSE motors and just manually operate them for now. I removed the bellcrank part that hangs down so I did not drill a hole in the inner fender which is where that hangs through. It was easy to install by just looking at the parts once you have them. I will post some pics of what it looks like later.
Gregster
01-08-2010, 08:02 PM
Here are some templates if that helps Jeff.
https://static1.pt-content.com/images/pt/2010/01/xoh2r9-1.jpg
https://static1.pt-content.com/images/pt/2010/01/2jb5f7s-1.jpg
https://static1.pt-content.com/images/pt/2010/01/ixfclw-1.jpg
https://static1.pt-content.com/images/pt/2010/01/nc1q8o-1.jpg
blainemeyer
01-08-2010, 10:16 PM
These assembly diagrams may help.
19sixtynine
01-09-2010, 10:13 AM
Thanks so much for the replies and help blainemeyer and Gregster, this will really help!
One more quick question, is there a difference in the hood latch? I seem to recall hearing people mention an "RS" specific hood latch ?
Thanks again all,
R
Rag-Rat
01-11-2010, 05:22 PM
The hood release on 69 models are the same. It's only 67 and 68 that require a different RS hood release.
19sixtynine
01-12-2010, 08:26 AM
Perfect, thanks for the info Chris!
juggernaut
01-17-2010, 11:10 PM
Thanks all!
I converted my 67' to and RS grill with a classic industries kit. The kit was rather disappointing, The components were good quality, it included a chassis assembly book but, no detailed instructions and no wiring diagram! (the 67' is the electric RS) I ended up with 3 relays and a bracket i didn't know where they went. Also, in the 67' the headlight switch is different and wasn't included in the kit. So, i went to radio shack, got some double relays, and made the doors operate with a signal from the headlight power.
I was discussing this on camaro forums and a guy posted about a kit that was complete. It may beat classic, check it out.
http://www.camaroforums.com/forum/showthread.php?t=44306
19sixtynine
01-18-2010, 08:45 AM
Hey juggernaut, thanks for the info...the conversion kits from Heartbeatcity seems pretty complete. I"ll be doing more research as I save up some coin, good lead though.
R
