dusterbd13
07-13-2008, 03:22 PM
OK, im odd. i know this, and im OK with it.
im looking at doing a throttle body injected motor with a rear mount turbo, much like the STS stuff thats out. only doing it on my own, and on my beater. were not talking about making crazy power, either, just some more than it currently has. lets say about 5lbs of boost. if this works, when i do the TBI small block in the vehicle, ill incorporate a turbo into the mix from the beginning.
i know that with the MAP sensor setup to read vacuum, it wont work too good with boost. what i was thinking was that i could fool it by taking a reading at the inlet side of the turbo to provide the vacuum. will that work? also, i was thinking about using a 3rd injector on a boost referenced switch so that im getting some extra fuel starting at about 3 pounds.
all this is actually on an 88 2.8 S10 that is being built for the GRM challenge.
please, let me know what you think. im seriously considering doing this if i can figure out the fuel system. the mounting and plumbing of the turbo wont be hard, just the management side.
thanks
Michael
thanks
Michael
