View Full Version : 67 Camaro DSE mini-tub install pics
venturabeachpup
07-09-2008, 05:57 PM
Hello everyone. Just thought I'd share an update with you. I really had a blast installing these (tubs) and they were easier than I thought.
Here I started with the drilling and cutting to remove the factory tubs.
https://static1.pt-content.com/images/pt/2008/07/1-1.jpg
https://static1.pt-content.com/images/pt/2008/07/4-1.jpg
https://static1.pt-content.com/images/pt/2008/07/6-1.jpg
Here I notched the frame and welded in the closeouts.
https://static1.pt-content.com/images/pt/2008/07/7-1.jpg
I used cardboard stencils to guide my cuts so the fit turned out nice.
https://static1.pt-content.com/images/pt/2008/07/11-1.jpg
https://static1.pt-content.com/images/pt/2008/07/12-1.jpg
https://static1.pt-content.com/images/pt/2008/07/14-1.jpg
I went with Boze for wheels. 17x11 with 5.5" of setback. I had them custom engrave the center hubs with the Camaro V flags emblem. The tires are 315/35/ZR17.
https://static1.pt-content.com/images/pt/2008/07/16-1.jpg
https://static1.pt-content.com/images/pt/2008/07/17-1.jpg
https://static1.pt-content.com/images/pt/2008/07/18-1.jpg
This is my target ride height.
https://static1.pt-content.com/images/pt/2008/07/20-1.jpg
I have not decided on an axle yet. Currie 9" or Moser 12 bolt???? Guys...This is where I would REALLY appreciate some major input. I will never race the car and my final hp will be @620 with a tremec 5 speed. The rearend will be equiped with a quadralink. I will post another update on that little project.
https://static1.pt-content.com/images/pt/2008/07/21-1.jpg
Thank you for looking!
Young Gun
07-09-2008, 06:04 PM
sweet! awesome install writeup/ picture thing!
chevelle19700
07-09-2008, 09:19 PM
nice
1969CamaroRS
07-10-2008, 05:53 AM
Looks really nice! What did you use for paint on the inside of the tubs?
BossaNova
07-10-2008, 06:03 AM
Tubs turned out great! Love the wheels too.
whytry
07-10-2008, 07:44 AM
Looks good, either rearend will do the job... What's the easier of the 2 to come across and cost wise?
PSV
07-10-2008, 09:00 AM
I have a currie 9 in with the polished aluminum housing 54.75 wheel to wheel width that would work well. It is new, used for mock up only and was to narrow for my leafspring set up. Its a 31 spline lg bearing housing and axle package. I will make you a great deal.
Motown 454
07-10-2008, 10:14 AM
you can't loose with either one . I checked with strange and I have 600 hp sml blk , They said the 31 spline would be fine so l,long as I wasn't always using slicks. So thats what i bought. And scence you already have it your one step further along.
mdprovee
07-10-2008, 10:29 AM
Nice job on the mini tub.
venturabeachpup
07-10-2008, 09:51 PM
In the picture it shows the tub with a couple of coats of black primer. I will put flat black paint on top of that.
Rybar
07-10-2008, 11:25 PM
Nice install, looks killer. And those wheels are sweet!
marinablueSS
07-23-2008, 10:03 AM
Looks great, nice touch with the crossed flags.
venturabeachpup
06-01-2009, 02:37 PM
After a long time of "not much going on", I finally decided on the chassiworks fab9 housing. I think it's a pretty cool unit.
https://static1.pt-content.com/images/pt/2009/06/Barehousing-1.jpg
https://static1.pt-content.com/images/pt/2009/06/backofhousing-1.jpg
https://static1.pt-content.com/images/pt/2009/06/backofpumpkin-1.jpg
https://static1.pt-content.com/images/pt/2009/06/gussetview-1.jpg
First things fiirst. I started with a pinion center guage to get things going. The guage takes the guess work out of figuring out the tube lenths.
https://static1.pt-content.com/images/pt/2009/06/piniongauge1-1.jpg
https://static1.pt-content.com/images/pt/2009/06/piniongauge2-1.jpg
After cutting the tubes, I just tack welded the DSE brackets on.
https://static1.pt-content.com/images/pt/2009/06/tackingbrackes-1.jpg
A quick mock-up to check everything before the finishing welds.
https://static1.pt-content.com/images/pt/2009/06/checkingforfit-1.jpg
Here's a couple of buddies that helped me hold everything correctly.
https://static1.pt-content.com/images/pt/2009/06/PICT0017-1.jpg
venturabeachpup
06-01-2009, 02:55 PM
The panhard frame bracket turned out to be the most work for me. I had to give it some minor adjustments, but it finally came around. At first I just didn't like the way it stuck out into the wheel housing. A few ours of TLC took care of it
https://static1.pt-content.com/images/pt/2009/06/PICT0001-1.jpg
Here's a couple of shots looking down the panhard bar toward the bracket.
https://static1.pt-content.com/images/pt/2009/06/PICT0007-1.jpg
https://static1.pt-content.com/images/pt/2009/06/PICT0011-1.jpg
right side
https://static1.pt-content.com/images/pt/2009/06/PICT0015-1.jpg
left side
https://static1.pt-content.com/images/pt/2009/06/PICT0016-1.jpg
DSE stuff fits!!! These shots were after the housing came back from the powder coat shop!
https://static1.pt-content.com/images/pt/2009/06/PICT0014-1.jpg
XLexusTech
06-01-2009, 03:51 PM
Nicely Done!
venturabeachpup
06-02-2009, 02:44 PM
Back from the powder coat shop and some afco coilovers.
https://static1.pt-content.com/images/pt/2009/06/apc3-1.jpg
https://static1.pt-content.com/images/pt/2009/06/apc1-1.jpg
https://static1.pt-content.com/images/pt/2009/06/apc4-1.jpg
https://static1.pt-content.com/images/pt/2009/06/apc5-1.jpg
Just a few more goodies and it's a roller! I'm thinking a 370-ish 31 spline posi unit with Willwood brakes. Thanks for looking.
Rybar
06-02-2009, 03:30 PM
Nice work Frank, really great progress thread here.
rickk
06-02-2009, 05:04 PM
looks good.:1st::1st:
rick k
Vegas69
06-02-2009, 06:40 PM
Killer work....DSE helps make you look good don't they.
Ratty 46
06-02-2009, 08:34 PM
Looks great. Good choice on the rear too. I do need to ask 1 question though, as I am in the process of the same set up with a more aggressive 4 link attached to my FAB9 in my 46 ford Ratty coupe, is about the solid rod ends on the coil overs .... let me know if they are up to the task of street driving.
Ratty 46
BLWN1
06-03-2009, 08:56 AM
NIce work, will those minis clear in a convertible?
Also did you rob the pepsi guy... lol
venturabeachpup
06-03-2009, 10:10 AM
Ratty 46
Sure thing. I'll make a note to update you. It may be a while though, because I'm strictly cash and carry on this project. Hec, you may be the one updating me. LOL
Post a picture of it in here somewhere; I'd like to see it.
Thanks to everyone for your kind words.
venturabeachpup
06-03-2009, 10:17 AM
I'm pretty sure they will clear but that's a question best answered by DSE.
Believe it or not I started a vending machine route as a side business and today it helps pay for the toys. Go Pepsi!!! LOL
Tyson A
06-03-2009, 04:47 PM
Hey Frank
The car looks great! Your showing some serious talent. Who did you use for the powder coating?
Tyson
lunchbox89
06-03-2009, 08:55 PM
what kind of wheels are those?
venturabeachpup
06-03-2009, 10:48 PM
Hey Frank
Tyson
Hi Tyson. Nice to hear from you. I used Madera Brothers Manufacturing here locally. (Bakersfield)
I'll PM you or call you with some info. I'd like for you to come by sometime.
venturabeachpup
06-03-2009, 10:58 PM
Those are Boze Forged wheels. The style or model is called "Boost".
17"x11" rears with 5.5" of setback.
17"x8" fronts with 4.5" of setback.
68/CamaroFL
06-04-2009, 05:20 AM
Excellent work! Nice Powdercoat!:twothumbs
1971CHEVELLE
06-04-2009, 03:55 PM
Awesome :1st:
