View Full Version : Question on tire size
85PTCutty
07-08-2008, 09:15 AM
I have a Olds and want to go with 18's what tire sive do I run?
fast Ed
07-08-2008, 10:38 AM
Olds what? Year, model, wheel width, lowered or stock ride height?
Help us help you. :)
cheers
Ed N.
85PTCutty
07-08-2008, 12:34 PM
Sorry, 1985 Olds Cutlass Supreme, lowered with Eibach's Pro coils. Don't know about width, maybe 18x8's on front and 18x9.5's on the rear. How wide can I go on the rear? What backspacing do I use? I'm new to the Pro Touring and love the look.
jackfrost
07-10-2008, 07:45 AM
the rear wheel wells of an Olds are pretty small. the biggest I've seen is a 255 tire, but I've heard of someone getting a 275 to fit w/ the perfect backspacing. the Monte and Regal wells are bigger.
if you go that big, make sure the body is centered on the frame. sometimes it can be off 1/2" or more, which will screw up your backspacing from side-to-side.
85PTCutty
07-14-2008, 03:56 AM
changed my mind I going with 17's if I run a 17x8 with 4" of backspacing will I be ok?
jackfrost
07-14-2008, 10:19 AM
i believe stock BS is 4 1/2", so it'd work, but might look weird.
