MastMotorsports
07-02-2008, 02:54 PM
https://static1.pt-content.com/images/pt/2008/06/mast_hot_rod_power_tour-1.jpg
Overview
We are creating this build thread to hopefully help those that are performing a similar swap.
For the past few months, we have been building a test truck for our development of GM 6L80E/6L90E 6 speed automatic transmissions. Our M-90 ECM is able to communicate with the transmission controller (TCM) that is inside the transmission. This means that there is no additional controller that you have to buy.
The truck is a 1968 Chevrolet Short/Wide that came to us with a carbureted SBC, TH350 transmission, and an open 12 bolt diff. The truck first got one of our L92 TI crate engines that use our M-90 ECM and wiring harness. Once we got the transmission sorted we installed a Mast Motorsports VVT Camshaft and valve springs to essentially make it one of our 525HP L92 TI HO crate engines. As stated above, the transmission is a GM 6L90E and the diff is an Eaton limited slip with a 3.08 gear.
We have just gotten done long hauling it on the Hot Rod Power Tour and plan on racing it at the LSX Shootout in Memphis this year. The truck ran great over the entire tour and got up to 17 MPG!!! (Depending on who was in the driver’s seat)
Here is an engine dyno plot of the first engine (Mast Motorsports L92 TI) that was in the truck.
https://static1.pt-content.com/images/pt/2008/07/StockL92TruckIntake93OctanePowerCur-1.jpg
After running this engine for a short time we swapped in a Mast Motorsports VVT camshaft to make this engine the same setup as our L92 TI HO crate engine package. The first 450HP setup we had was no slouch by any means, but after the cam swap this truck was an absolute beast. The 75HP increase from the cam was pretty impressive to everyone here that had driven or ridden in the truck before and after the cam swap. The dyno plot below shows the power gains seen between the L92 TI and L92 TI HO. Notice that it makes WELL over 400 ft.-lbs. way down at 2500 RPM thanks to the VVT!
https://static1.pt-content.com/images/pt/2008/07/L92TI_L92TIHO_OVERLAY-1.jpg
Engine Installation
After the SBC was removed, the engine bay was cleaned up and the L92 was dropped in. We used Early Classic Enterprises engine mounts (911-GenIII). These required drilling just a few holes in the front cross member and use the stronger clamshell style engine mount. This was our first time using these mounts and we were very pleased with the quality and engine placement. One nice thing about these mounts is that we used the stock truck pan that came on the L92. That saved $250-$300.
https://static1.pt-content.com/images/pt/2008/07/DSCF1698-1.jpg
https://static1.pt-content.com/images/pt/2008/07/DSCF1699-1.jpg
https://static1.pt-content.com/images/pt/2008/07/DSCF1770-1.jpg
https://static1.pt-content.com/images/pt/2008/07/DSCF1857-1.jpg
https://static1.pt-content.com/images/pt/2008/07/DSCF1858-1.jpg
The L92 almost looks like it should have come in the engine bay from the factory. We used Pacesetter F-Body headers (72C2256). These have 1-3/4 primaries and fit after reasonable dimpling and frame notching. Doug Thorley released a set of swap headers designed for this truck after we bought ours (THY324Y-C), so that is another option.
http://67-72chevytrucks.com/vboard/showthread.php?t=287231
https://static1.pt-content.com/images/pt/2008/07/DSCF1776-1.jpg
https://static1.pt-content.com/images/pt/2008/07/DSCF1778-1.jpg
https://static1.pt-content.com/images/pt/2008/07/DSCF1781-1.jpg
https://static1.pt-content.com/images/pt/2008/07/DSCF1882-1.jpg
Overview
Engine Installation
