View Full Version : Fast Burn headers for first gen Camaro's
Rag-Rat
07-01-2008, 07:16 AM
I'm putting together a 350 with GM's Fast Burn aluminum heads for my 67 Camaro and in my research for headers found that Edelbrock is coming out with a stainless steel header #65093 (not yet available, unknown price) for 67-69 Camaro's and 68-74 Nova's that use "D" port heads. 1-3/4 tubes and 3-1/2 collectors. I know Sanderson and Street & Performance also offer headers. Has anyone used these before and how was the fit & finish?
CarlC
07-07-2008, 08:02 AM
3-1/2" collector? Wow.
Rag-Rat
07-07-2008, 05:37 PM
That's what their on-line catalog states. When I contacted Chris Rowe from Edelbrock he said they were still in development, so I guess it could change if they have floor space conflicts. I'm curious to see an image of them when they become available. I'm in no hurry, I'm gathering funds and parts to turn my motor into a hydraulic roller.
TnBlkC230WZ
07-09-2008, 06:27 PM
Dougs also makes headers for your combination.
Rag-Rat
07-09-2008, 06:49 PM
Chris,Unfortunately we do not offer any headers for the fast burn applications.Thank you for your inquiry.Tech Dept
DeltaT
07-10-2008, 07:24 PM
Rag-Rat,
I also used a Vortec-style head (like the Fastburns, but I used Edelbrock E-Tec 200's. I also have a set of Fastburns and they bolt and match up perfect there too.) What I did was buy a header that fit my car (I used 1 3/4" Hedman Huslers), then plugged up the original hole and drilled new holes .250" lower on the header flange to accomodate the raised exhaust runners.
A testfit after the mods showed a perfect matchup between port and header. I tweaked the holes a little with a rattail file, beadblasted the whole set and sent them out for ceramic coating. They've been working fine since. Here's a picture - if you look closely at the holes you can see a little 'eyebrow' where I put the plugs in:
Jim
COMP
07-10-2008, 07:28 PM
what are all those dents from ???
69keith
07-11-2008, 08:08 AM
I used the Doug's 375y on my fast burn D-Port heads.
Keith
DeltaT
07-11-2008, 04:14 PM
I added one clearance dent for extra starter clearance. It's not as bad as it looks - maybe 1/4" deep max. The rest are reflections and mild surface irregularities that the flash brings out.
Jim
COMP
07-11-2008, 04:24 PM
OK,,,they look bad on my old screen
Rag-Rat
07-12-2008, 03:25 PM
Thanks for the info. Are the E-Tec heads angle plug or straight plug? I take it there were no issues with the headers coming in contact with the starter, oil filter, p/s gearbox or floorboards? I have a fab shop near me that could probably do the work.
CarlC
07-12-2008, 07:25 PM
For well fitting headers, you may want to check into Lemons and Stahl. They likely won't be in any catalog and will require a phone call. They are not going to be inexpensive, but will be very nice parts.
DeltaT
07-16-2008, 09:23 AM
Rag-Rat,
Check the starter for clearance - you might want another 1/4" of clearance hence the visible ding in my header tube. Can't beat a test-fit before coating for verifying your specific clearances.
Jim
kp.touring
07-18-2008, 06:21 PM
Lemon's Headers! Dan build headers that work with the raised ports of a fast burn head. They are not cheap, but they fit and are art work.
Kevin
