Robprime
06-28-2008, 10:38 PM
Hello,
Newb here, and especially when it comes to suspensions.
I searched this forum for info about leaf spring setups and was pleased to see that the consensus is that leaf springs can be made to work well if set up properly, which is great as I am on the junkyard budget.
I have an '85 Lwb Ranger Std Cab that has a '78 302/C4 installed. The body was lifted 3" to make more room and it has worked out nicely in that respect. But it didn't do much for the handling.
I'm tackling the rear suspension first.
This truck still has the original 7.5" 3.45 LS rear end with 28 spline axles and drum brakes. It is a spring over axle setup that is 56.5" between the brake drum backing plates. The axle tubes are 3" in diameter and there is 39" of spacing between the spring mounts on the axles. The upper ends of the springs are mounted to brackets riveted to the outside of the frame rails, fixed in the front and shackled in the rear. There is about 2" of space between the outside of the frame and the inside edge of the springs. The shocks are mounted to the inside of the frame rails and are staggered with the drivers side to the rear of the axle and the pass. side to the front, and leaning at a pretty good angle, maybe 30* or so back to front. They look pretty straight up and down in the side to side direction. I run 32" tires on 15" wheels in the back and 31" on the front.
Sorry about this long description. I'll have the bed off early this week and will see about posting some pics. I am in the process of test fitting a 23 gal. Bronco II rear mount fuel tank in place of the 17 gal. side tank there now, and I need the bed in place to check clearances and such.
But anyway, I have a '95 Explorer 8.8" rear end, 3.73 LS with disc brakes that I want to use. Besides the brakes and lower gearing, this rear end is some 30% stronger than the 7.5", with 3 1/4" tubes and 31 spline axles. However, it is an axle over spring setup and is somewhat wider than the 7.5", measuring 59 3/4" between the plates, although the distance between the spring mounts is still 39". I consider that a good thing as I've always felt that the truck was a bit too narrow for its height.
Now for some questions. It's obvious that I'm going to be doing some spring and shock mount relocation and I'm wondering how best to set things up.
I've read that it's best to mount your shocks as far outboard as possible, pretty much straight up and down in the back to front direction, or perhaps with a small angle rearwards at the top of the shock to allow for the rear end moving towards the back of the vehicle as the leaf springs straighten out during hard acceleration or hitting a bump or whatever.
And that it is best to also have the shock mounted straight up and down in the side to side direction also, or perhaps again with a small angle inward at the top to allow for chassis roll during hard cornering or hitting bumps in curves.
Hopefully I am understanding this correctly.
It is really not possible for me to mount the shocks to the outside of the frame rails with the springs as they are now. there is not enough room to get the shock past the springs down to the axles with the axle under spring setup it has now.
And I'd like to change to a axle over spring configuration if I could as I understand that that helps greatly with spring/rearend twist under hard accel and also serves to lower the CG a bit.
I see two ways I might do that. I could mount the springs inboard directly to the bottom of the frame rails (I think that is the normal Explorer setup), which would raise the rear of the truck just about enough that I could switch to an axle over spring setup and the ride height would end up about the same. This looks like it would be very strong and stiff but would narrow the spacing between the springs by about 4" on each side. Maybe not so good in that respect, what with leverage and loading and all. It would let me make free with the shocks outside the frame rails, though.
Or I can fab some brackets for the springs that move them outward that extra 1.5" on each side that the wider rearend gives me. And I could make them so as to move the spring mount points down towards the bottom of the frame rails, maybe allowing me to still go to an axle over config much farther out on the axle tubes. That would open the 2" space between the frame and spring to 3.5", and I might be able to squeeze an extra .5" or so in. That might just be enough room to squeeze in a shock outside the frame rails. Not as solid and strong as the under frame setup, being cantilevered out like that, I wouldn't think. Leverage maybe causing some frame flexing?
Would I have to keep a staggered shock arrangement if I go to an axle over spring setup? And could I get by without traction bars? I found the panhard + leafspring thread interesting also.
If anyone would like to weigh in with some critique, ideas, anything, I would welcome the help. I have read of guys doing this swap before but they mostly just placed the wider rearend back in the stock setup by welding on spring and shock mounts in the normal places. I would like to improve the handling a bit if I can. This truck is capable of moving pretty fast as it is and I even have a 351W I'm thinking of stuffing in.
Rob
Rob
