    Results 1 to 20 of 20
      May 2008
      Mesquite Texas
      17 x 8 on stock 67/68 camaro fronts?
      has anyone ever been able to cram a 8 inch wheel on stock front suspension on a 67 or 68 camaro WITHOUT the tires rubbing?
      If anyone can prove it, I may do the same. I have never played around with anything larger than a 7 inch rim on stock suspension.
      May 2008
      Mesquite Texas
      According to the database, looks like this guy has.
      But the backspace is questionable.
      Jonathan
      68 Camaro
      ROH
      Snyper
      17x8
      4.5?
      17x9
      5?
      235/45
      275/40
      stock with all hotchkis springs and swaybars
      Sep 2004
      savannah,ga
      I have done a similar thing with my 67 Firebird. the tires will rub a little. It rubs on the inside rear, on the frame. An adjustable steering stop or a built up stationary stop stops the rub.
      Den Helder, the Netherlands
      Country Flag: Netherlands
      Quote Originally Posted by Tom Welch
      I'm driving around on 17x8-1/2 with stock arms. Only thing you have to do to prevent rubbing is to do as the above comment says.
      Rubbing is racing, right?
      Seriously it's not a real issue. I have 17x8 with 5" BS and 245/45s on a '68. The only time it rubs is on the frame at full lock just barely. If it was on the fender where you could damage the tire, or a constant rubbing under load, yes that would be a problem. But on the frame its just going to show rub marks if any and only if you hit the stops which is usually during parking manuvers if at all.
      May 2000
      I did it with 5.25" bs. Any more bs and it hit the tie rod.
      Rub the frame slightly at full lock.
      USA
      17 X 8 with 5" backspacing and a 245/45/17 will clear on the front.
      As long as the car isn't lowered to much.
      My tires will barely rub on the inside against the frame at full lock.
      I haven't had any tie-rod end clearance issues.
      Jeff Tate
      U.S.A.
      Nov 2004
      Dallas Texas
      17x8
      I had 16x8 on the front of my 69 Firebird with a 255/50/16 that fit with NO rubbing so 17x8 will fit too - I think CarlC has 17x9 or 9.5 on a red 67-8 camaro w/o problems
      Rich
      69 Trans Am "TireBird"
      M6 / LS6 minitubbed DSE Sub
      C5 frt LS1 rear disc brakes
      https://www.pro-touring.com/forum/showthread.php?t=14992
      69 R/S Z28 302
      15 Camaro ZL1
      90 Formula next project
      Fontana, CA
      Quote Originally Posted by zman1969
      17x9.5 and he used the Speedtech LCA adjustable steering stops to prevent frame rub. He still has a decent turning radius and never heard his tires complain on anything except the road under full throttle!
      Nick R.
      May 2008
      Mesquite Texas
      Interesting..
      I may give it a whirl. Yes, that is the rub I am talking about.
      When it is fully locked, you hit the frame.
      Where are these adjustable steering stops available from?
      Can anyone post a pic and a link?
      I might give a 17 x 8 a whirl after all. Thanks for all the posts on the subject.
      Fontana, CA
      FYI, my 17x8s 4.5" bs rub the frame as well. I have not yet but plan to drill and tap the hard steering stop in my GW LCAs and place in like a 1/4"x20 or similar adjustable stop.
      Quote Originally Posted by 1BADRS
      On Carl's car they are part of the LCA from Speedtech and are similar to what I described above.
      Nick R.
      May 2008
      Mesquite Texas
      Quote Originally Posted by JEFFTATE
      I am planning on using 2 inch hotchkis lowered drop springs...
      Should I, or Shouldnt I?
      I can handle a small amount of frame rub. But I am so dam picky, id call that rubbing...LOL.... should I grit my teeth and go with
      17 x 8 with 245/45/ 17's TT II's...on a 8 inch rim or a 225/45/17 with a 7 inch rim like I did last go around?
      Im skeered.. LOL...
      Jun 2008
      elk grove, ca
      the frame rub is not a big deal. do you have drums or discs? the drums will rub more. you don't have to 'stuff' an 8 inch wheel in there in large sizes (17+). it will fit. the best backspace according to dse is 4 7/8 (i'm pretty sure they assume disc brakes which push the wheels out). i run 4 3/4 without issue on discs. the drums rubbed a little, but only made the frame shiny. you shouldn't base backspace on drop, either. no matter what your drop, the suspension travel is the same. it's limited up or down by stops. make sure your wheel fits in within the stops. on a personal note: you might grit your teeth and get TTIIs, but i'll throw up in my mouth a little. TTIIs are the mullets of the 2ks. you will regret it...
      john j.
      http://i175.photobucket.com/albums/w...g/122_2287.jpg
      1969 camaro
      1968 firebird
      2001 corvette
      May 2000
      Quote Originally Posted by 6'9"Witha69
      Also, Carl used short steering arms.
      Here's my old car, 17x8, 5.25" bs. Anymore and tie rod (it's the yellow thing) would of hit the wheel. A little grinding on the tie rod may fix that, not sure if I'd want to do that though.
      May 2008
      Mesquite Texas
      Quote Originally Posted by guccieng
      It will be disc brakes. I want to run a negative offset, 4" backspace, not more than that.
      I won't throw up. I can't find anything that look good on a 68 camaro for less than a grand.
      $$$$ my friend.
      4" backspace wil not work, you'll rub on the fender. Maybe if its with a 7" riim, a 225 tire, suspension set for negative camber gain (and negative static camber) but it will be close.
      Hot Wheels from Discount Tire look nice and are less than $1G. At least you don't see those on half the cars at a show.
      May 2008
      Mesquite Texas
      Quote Originally Posted by amcmike
      I have ran 4" backspace before. But like you said, it was a 7 inch rim. I prefer that look actually, so I will probably stick with the ones that I know will work.. .
      Show me a pic of those wheels you are talking about.
      I Drive a black escalade on http://www.68camaroproject.com
      They are sold exclusively through www.DiscountTire.com (also available at their dealer outlets).
      Aug 2006
      San Francisco, CA
      www.camaros.net has an active thread in their "Wheels and Tires" section so you can see what people have fit to their cars.
      Steven
      1968 Camaro: Project "TRACKDAY"
      Latest Track Weekend Video
      Build in Progress
      Jul 2001
      Detroit, Michigan
      "It ain't a Hot Rod if the tires don't rub." ~ Mark Stielow
      1968 Pro-Touring Camaro LS1
      Project: Next Year
      - Start date; June '01
