View Full Version : Lost DSE koni adjustment instructions
Bow Tie 67
06-27-2008, 03:14 PM
My garage is a mess, I can't find the instructions for my DSE Quadra-link Koni's. I need to adjust them prior to a track day tomorrow.
I think depressing the button and turning the aluminum body counter-clockwise is stiffer. ( counter-clockwise with the upper rodend in a vise or if you looked at it from the body end )
Matt
mpozzi
06-27-2008, 06:03 PM
Yes ... depress the button and rotate the shock shaft counterclockwise. Each "click" stiffens rebound approximately 30% so keep that in mind when you adjust.
For my '02 SS, I run the Sport Koni's that have this same type of adjustment. One "click" up from full soft is a good starting point.
Hope this helps and good luck at your track day tomorrow.
Cheers,
Mary Pozzi
06-27-2008, 06:22 PM
Who ever said a picture is worth a thousand words was NOT talking about a Koni instruction sheet!:secret:
Bow Tie 67
06-27-2008, 07:38 PM
Tell me about it,
Thanks for the info, I found this
http://www.automotivehelper.com/topic891031.htm
I ended up going two click toward the firmer from what they said. ( rotated full counter to start then two click clockwise. )
DSE Jason
06-30-2008, 11:29 AM
Matt,
This is Jason from Detroit Speed. I've doubled checked our instructions and the adjusment is as follows;
To increase rebound, Depress the adjusting button and turn the piston rod one or more clicks to the right (clockwise), and release the adjusting button. To decrese rebound Depress the adjusting button and turn the piston rod one or more clicks to the left [counterclockwise] and release the button.
I apologize for the late reply, I was onsite at a Good Guys Show this past weekend.
If you run into any other questions please feel free to call and we'll do what ever is necessary to get your questions answered.
Jason
Detroit Speed
